Need help with microjig Grr-Ripper on SawStop table saw
Forum topic by CTW posted 12-27-2014 06:20 AM 2854 views 0 times favorited 8 replies Add to Favorites Watch
View CTW's profile
48 posts in 1246 days
12-27-2014 06:20 AM
Topic tags/keywords: question jig tablesaw sawstop
I hope I am posting this question in the right forum. I am very new to woodworking and I am working in a vacuum. We live on a ranch in a very rural area and my only contact for questions is over the internet. I have a SawStop table saw and my husband purchased me a Microjig Grr-Ripper for Christmas. I just unboxed it and have not assembled it yet, but I have viewed the accompanying DVD. It appears to me that in order to use the “Gripper” I would need to remove the riving knife (as well as the blade guard). Does anybody else have a SawStop and have experience with the Gripper? I’m just unsure if I should in fact remove the riving knife (how safe is that?) and if I should even keep the Gripper. Input is welcome.
Thanks, CTW
8 replies so far
View Purrmaster's profile
915 posts in 2029 days
#1 posted 12-27-2014 06:33 AM
I don’t have a Grr-ripper so I’ll leave that to people who do.
But I do have a table saw and I would caution you about removing the riving knife and the anti-kickback pawls. The SawStop will probably keep you from cutting off your fingers. But it won’t do anything to prevent kickback. That’s what the splitter and pawls are for.
Just my two cents.
View Woodmaster1's profile
905 posts in 2523 days
#2 posted 12-27-2014 06:34 AM
You need to remove the blade guard but put in the riving knife when making rip cuts less than the whole width of the gripper. Or you can just use the riving knife and no blade guard all the time. The safety device should protect you in case of a mishap. The gripper should prevent any mishaps.
View jtm's profile
226 posts in 1573 days
#3 posted 12-27-2014 06:36 AM
Since the riving knife moves up and down with blade height, there is no reason to remove it. For a standard through-cut, there shouldn’t be any problem.
The blade guard on the other hand, needs to be removed, as it will get in the way of the Grrripper. For this reason, I very rarely use my Grripper.
View CTW's profile
#4 posted 12-27-2014 07:33 AM
Thank you to everybody who answered. I will go out to the shop tomorrow and spend a little time looking at this.
4910 posts in 2430 days
#5 posted 12-27-2014 11:58 AM
I think you’ll find the riving knife just a hair shorter than the blade. That may vary depending on the blade, but on mine it’s maybe 1/16” or so shorter than the blade. You will have to remove the guard, but other wise the gripper should work with the riving knife in place, obviously the blade can’t be too high for that.
View paxorion's profile
1107 posts in 1982 days
#6 posted 12-27-2014 01:39 PM
As others have said, the guard needs to be removed to use the Grr Ripper. The riving knife should still be used and is compatible with the Grr Ripper. I use my Grr Rippers all the time with the riving knife.
-- paxorion
View bonesbr549's profile
1517 posts in 3003 days
#7 posted 12-28-2014 02:30 PM
As others have said you can’t use the guard for obvious reasons, but I used mine on my sawstop for about 6hrs yesterday and worked just fine with the riving knife in place. My feet are killing me but they worked just fine.
I’ve been using two of those for years and love em. !
View CTW's profile
#8 posted 12-29-2014 04:47 AM
Just a quick note to thank everybody. I did go out and take a close look at the saw and realized I had the total blade guard installed instead of the riving knife. And yes, the riving knife did track to the blade height. So that mystery is solved, but I have many more.
Thanks, CTW
