| Forum topic by jm540 | posted 278 days ago | 1298 views | 0 times favorited | 35 replies | ![]() |
278 days ago |
Topic tags/keywords: jig resource question trick carving tool planer miter saw router milling joining shaping Where I live there are always radial arm saws to be gotten for a good price. after seeing the post about that shop smith thing the guy made into a mortiser I got to thinking if I bought one of these could I take the saw off and install a 3hp router. has anyone seen anything like this or have anything like this any thoughts? -- jay Rambling on and on again |
278 days ago |
I guess the trick would be finding a good way to mount the router. It’s an intriguing idea, though. -- Charlie M. "Woodworking - patience = firewood" |
278 days ago |
anything like what’s posted here? http://sandiego.craigslist.org/nsd/tls/1047711841.html -- San Diego, CA US Navy |
278 days ago |
very much like that the possibilities are endless having trouble writiing a vega duplicator is coming today and every loud truck has me running to the window I think I may be a toolaholic…Na -- jay Rambling on and on again |
278 days ago |
Jm5400, Now I have seen routers on vertical panel saws. I have not seen too many Radial arm saw/router retrofits. There is a advantage to having the ability to having the material still and the router move. The abilitry to make make 90 degree trims is very nice. There however is a better way to do this. The first would be to get a couple of linear bearings. I have made many custom jigs with linear bearings and you can also make a router that will make a long cut (with a long linear bearing). You can find linear bearings on ebay that are very inexpensive. Linear bearings such as THK, Thmpsions, etc are very accurate and are used in cncs so if you are making your “raidail arm router” or “panel router” these will work well. I have made many contraptions like this so if you need any advice or help I can tell you how to make these. If you are dead set on a radial arm saw, you will likely have to make a bracket or have one machined. The way you would do this is to make a bracket that will mate into the base of your router. You will also have to have a bracket that will mount to where the saw mounts. I would recomend using aluminum. If you have the footpirnt of your router and the the dimensions of where this bracket will mount, I can help you design this. Cheers, Ben |
278 days ago |
I had a Ryobi 8 1/4” Radial Arm Saw that had a 1/4” router chuck on the opposite end of the mandrel. It was good for some overhead cuts and for using masonite patterns etc. There’s still a lot of these out there for sale, used or new. -- If Stradivarius was alive today, he'd be using Gorilla Glue. |
278 days ago |
Think I remember seeing Norm use a shaper head setup on his. He had the motor locked in position and you push your wood thru like on a router table. Looked scary to me…maybe Norm’s real intentions were to prove to us all that he’s got a set! -- Bob Vila would be so proud of you! |
278 days ago |
poopie what is that model number -- jay Rambling on and on again |
278 days ago |
sounds like gooda and I have thought of that before. The thing is how useful would it be vs. time and money to build it. With mortising big enough peices you’d even consider using something like that for it’s always better to bring that tool to the work. But if you have the time go for it -- Rogue |
278 days ago |
The “Router Boss” and “Woodrat” seem to use similar principles. ($1000.00??) So the question is can their functionality be equaled using a radial arm saw foundation for less cost. -- Joe |
278 days ago |
I’ve got the same saw as poopiekat does the “RA200” had it for 20+ years. I have used it as a router and it did a fine job, but I prefer it as an RAS instead of the router, that’s just MY opinion. -- Respect your shop tools and they will respect you - Ric |
278 days ago |
I swear I have seen a bracket that you can mount a router to the arm of an R.A.S. I’ll keep an eye open to see if I find one. -- He said wood...http://hickbyassociation.blogspot.com/ |
278 days ago |
linear bearings sound great. -- jay Rambling on and on again |
278 days ago |
The Ryobi mentioned above was the unit I used to get some really different cuts that would be hard to achieve, especially where the router axis meets the wood at an angle other than perpendicular. With the articulated head, many cuts can be achieved that would be otherwise impossible. I got rid of mine, though, along with the BT2000 saw and just about every other Ryobi tool, because they’re pretty crappy in general. I still do love my 4 1/2” oscillating disk sander, going on 20 years and still a champ. Googling Ryobi RA200, the first few results are for a product recall. -- If Stradivarius was alive today, he'd be using Gorilla Glue. |
278 days ago |
When I got down to my shop I realized my last post was very irresponsible. Saftey first and it is no joke so don’t try to reproduce my compound miter router and if you do send me some money. BUT SERIOUSLY use a UL approved tape -- jay Rambling on and on again |
278 days ago |
jm540 that looks way to dangerous to even comtemplate and please remember there are kids on here that might think i looks cool and try and replicate what you have done please take the pic off andy -- cut it saw it scrap it |
278 days ago |
I don’t agree with the picture coming down. There’s nothing wrong with a little fun. If you don’t like the fun in it, then that’s fine, but if you take it that seriously, then perhaps it’s time to step away from the computer for a while. I take that picture as a fun tribute (whether intended or not) of the FINE Mr. Red Green. He would certainly approve. I don’t feel any of the kids that are on this site, would be dumb enough to try this, nor, because it’s a cheap old Black & Decker router, would it do much harm. Take time to laugh, while still being respectful and smart. -- Respect your shop tools and they will respect you - Ric |
278 days ago |
There’s been way too many people trying to step in as LumberJock Police lately…. Not good for the site. Most of us are adults….... and most adults don’t like being “told” what to do. Not referring to you Ric -- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood. |
278 days ago |
I don’t wanna make anyone mad but I will tell you bluntly if you have a child that is not mentally capable of seeing this as funny or unsafe and you allow them on the internet and/or around power tools unsupervised you are a horrible parent (I really mean unfit/idiot).Who needs to have thier children taken from there custody because my picture is the least of your worries. Further more if any of you. see on the news that a child was mauled by a compound miter router on the news it is your duty to go to the hospital w/social services or a baseball bat I prefer both to straighten there parents out I like it here good fun sorry not taking it down -- jay Rambling on and on again |
278 days ago |
I do need to point out you should take the blade out of the saw it cuts the tape ps when I was 7 my mom showed me how to use a drill motor with a spade bit and left me drilling holes in a stump all afternoon she is osha 50 certified and I have all my digits -- jay Rambling on and on again |
278 days ago |
I agree with you jay. -- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood. |
278 days ago |
I agree with pommy but only because you taped the safety switch in the ON position. What do I know? I thought my daughter was smarter than to have octuplets. Lee -- No piece is cut too short. It was meant for a smaller project. |
278 days ago |
saw dust my wife just had to watch your daughters interview on TV tonight -- jay Rambling on and on again |
278 days ago |
are you guyzzzz kidding? Red Green would be drooling over that saw/router or what ever it is! -- ART- WINSTED CT. Just Remember! If you walk a mile in another mans shoes ----your a mile away and you've got his shoes! |
278 days ago |
All right, you guys!! -- If Stradivarius was alive today, he'd be using Gorilla Glue. |
278 days ago |
My vote: Funny as heck picture… Reminds me of the Red Green show and the nutball things he’d put together.. ;) Before my father passed away we were digging through my grandfathers old shop getting the place ready for sale. There was an interesting, but not well used mortise machine in the corner. Apparently my grandfather disliked using it for building cabinets, so he just did it manually. artie: I see you’re a fan, too! :D Sawdust2: That’s your daughter? Congrats to her.. I think.. ;) No, really, grats.. And good luck to her! poopiekat: You’re aware that jm540 trashed jm540’s own thread, right? Considering jm540 posted the picture… :D :D People need to lighten up, eesh. |
278 days ago |
Oh.. You might enjoy this link, BTW. |
278 days ago |
Back on a serious note: LOL Jay, I have the DeWalt DW1251 RAS, and there is a mount on the motor housing to hold an OEM router bracket. Try looking at their website and see if you can glean any ideas about how to mount the router. I’ve used the DeWalt shaper kit, but never the router kit. -- I may be schizophrenic, but at least I have each other. |
277 days ago |
Sorry i was being to sensitive had a bad day and didn’t see the funny side but today i see it sorry for being a PRAT …........... andy -- cut it saw it scrap it |
277 days ago |
I recently picked up a used Craftsman radial arm saw and it has a router feature on the arbor opposite the blade. It was the only one I looked at that had this feature. I havent’ used it and I suspect there are limitations due to the slower speed. -- If she asks please tell my wife that I can sell my tools for what I paid, okay? |
276 days ago |
If any one has apicture or model number of the craftsman I would like to look at that option -- jay Rambling on and on again |
276 days ago |
It looks like there are quite a few RAS with built in Routers… You mentioned motorless cnc, have you seen spalms he built? -- A thing of beauty is a joy forever... |
276 days ago |
hello JM540: I have been watching to see if anyone would discribe the machine that i built .Here I am thinking “this is going to fund my retirement” but alas SEARS beat me to it. Yes I built a radial arm router that is the coolist tool in my shop. The router is sentered where the saw motor should be only it points down,that is until you tilt it forward,or backward,left or right ,virtually any angle is possible. so if your router bit isn’t the right shape you can tilt it to conform to the shape you want.—you just have to be carfull with it.If you need the handle on the right just turn it around or put it on the left.—I’ll have to hunt down my pictures and post them. ART -- ART- WINSTED CT. Just Remember! If you walk a mile in another mans shoes ----your a mile away and you've got his shoes! |
276 days ago |
artie don’t be afraid to toot your own horn that’s why I asked here I would greatly appreciate it I got to thinking of the possibilities and got a head ache but some of the ones I haven’t already listed are you no longer need a chamfer bit of any angle as you can tilt the router and use a plunge mortising or dado or staight cut what ever you have. I could level a board to big for my planer ( I would probably use hand planes but I could make a couple quick passes for reference I am always creating profiles by running my 10 bits at different depths and or on different faces to try to create something different I could now run them at different angles( I would like to invent a profile and put it on every original piece I make) You dont need that jig David Marks made to make a spherical relief in something you just go to center lock the slide lock unlock the chamfer and move by hand rotate repeat and so on -- jay Rambling on and on again |
276 days ago |
Even if the compound miter router was posted by someone other than the OP, I still wuldn’t call it threadcrapping. Just too funny. I sold Craftsman bench power tools for a few years and moved a few RAS’ with the router arbor but I never heard of anyone actually buying the collet adapter and using it. Some of us mentioned it as a feature, but it seemed so obscure we often didn’t bother. I still like artie’s homegrown version better, if only for it’s creative execution. -- Quidquid latine dictum sit, altum viditur |
276 days ago |
While working on my last project I have vowed to never cut another dado in plywood with a circ blade and this is where the road lead me. -- jay Rambling on and on again |
| Forum | Topics |
Woodworking Skill Share
2937 |
3968 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
