Hinged undermount planer
Forum topic by Mark2457 posted 12-26-2014 11:20 AM 1921 views 0 times favorited 16 replies Add to Favorites Watch
View Mark2457's profile
Mark2457
49 posts in 1611 days
12-26-2014 11:20 AM
Hi All
I have a 1.5 car garage and .5 of it is what I use for my workshop. I have a table saw mounted on a mobile base with a router table to the right of the blade. i have an incra fence system with 92” rails.
I want to mount my planer (Steeelcity 40300HC), so that it can pivot underneath (upside down for storage) and be swung out and up for use.
I was thinking of using something like the revashelf stand mixer support, but it’s only rated for 60 lbs.
The rails have slots that i can use to bolt hinges (or anything else to) and are about 4” thick. So I was considering building a 4×2 base with 1/2 ply to attach planer to.
I have two issues. Types of hinges and support once folder up. (Ideally I’d like to find a locking hinge, but would need to support 80-100 lbs. Anyone ever done anything like this or have any suggestions?
Diagram attached. Lighter colors show stowed position
TIA
Mark
16 replies so far
View pjones46's profile
pjones46
1001 posts in 2670 days
#1 posted 12-27-2014 02:58 AM
A Lifting Shelf Hinge for Mixer, Blender or Other Appliance similar to this would be Ideal. Do some surches on the internet to see if there is anything that would handle your weight load and heigth requirements.
-- Respectfully, Paul
Mark2457
#2 posted 12-27-2014 06:47 PM
Thanks for reply. As I mentioned in original post, that was my original pan, but was unable to find anything that hold sufficient weight.
View KayBee's profile
KayBee
1083 posts in 3273 days
#3 posted 12-27-2014 09:46 PM
Why don’t you make a flip top stand that stores under your table saw. You just leave one side empty and roll it out when you need it. Something like these to give you an idea
http://lumberjocks.com/projects/49493
-- Karen - a little bit of stupid goes a long way
pjones46
#4 posted 12-28-2014 12:51 AM
The rail looks like one of 80/20's modular framing solution. You might look at their site and see if they have anything that would help.
KayBee
#5 posted 12-28-2014 02:26 AM
Second one was supposed to be this one
http://lumberjocks.com/projects/89471
pjones46
#6 posted 12-28-2014 02:35 AM
KayBee,
http://lumberjocks.com/projects/89471 is ingenious. Kudos to glooblooz.
KayBee
#7 posted 12-28-2014 02:44 AM
Yes, he did a great job. I’m thinking that might be easier than the whole pivoting shelf thing.
pjones46
#8 posted 12-28-2014 02:52 AM
Allot easier due to the weight and could still meet up with the work top.
View TheDane's profile
TheDane
5441 posts in 3690 days
#9 posted 12-28-2014 02:56 AM
I did a flip top for my planer and miter saw:
Click for details
Mark2457
#10 posted 12-28-2014 03:29 AM
Thanks for the replies. Those flip-top things are very nice, Unfortunately, I can’t wheel anything under the saw. The mobile base is about 8 feet wide, as it has to hold the saw and the legs to support the far end of the 92” rails. I have about 52-inch to the right of the blade. The saw and extension legs (about 6 feet to the right of the saw) are on a single mobile base. Something like this: http://www.tooltrip.com/tooltrip9/woodworking/general350/general350.htm
One possible solution could be to undermount some 100lb capacity slide out rails that hold a flip-top. Will give it some thought.
Thanks for suggestion
Mark
13608 posts in 3368 days
#11 posted 12-28-2014 03:56 AM
maybe a box that rides under the saw rails
with something like the hand crank on the planer
roll box out
and raise the tool to the right height
that way it won’t be a problem with outboard weight on the saw table
maybe hand crank with thread rods
or electric or air driven rams
to raise and lower
Mark2457
#12 posted 12-28-2014 01:59 PM
roll box out
that way it won t be a problem with outboard weight on the saw table
to raise and lower
- patron
I like that idea. Will have to see if I have space to raise it (as I have a router table insert with undermount router router to the right of the blade. Not sure where (or which) hardware I’d use. Most things i’ve seen like that have a threaded rod at one end and slides at the other. I think it would be too heavy to do that so I’d have to have threaded rods at both sides. I assume I would then need a horizontal rod attached to some sort of drive (hand crank or motor) and then cogs to transfer that to the vertical threaded rods that would raise and lower the unit.
Sounds like a real fun project, just not sure where to get all that gear (and get the correxct stuff)
Regards
Mark
View REO's profile
REO
928 posts in 2101 days
#13 posted 12-28-2014 02:39 PM
http://i633.photobucket.com/albums/uu55/oreos40/Facebook/Saw%20planersanderrouter%20pod/62059_4544151652429_171062030_n.jpg
http://i633.photobucket.com/albums/uu55/oreos40/Facebook/Saw%20planersanderrouter%20pod/403233_4544148212343_57950003_n.jpg
I used the mixer lift type mount for the sander. when the planer is upright it the out-feed is level with the work table. wood can be placed on the saw/router table for planing or re-running.
Mark2457
#14 posted 12-28-2014 03:01 PM
- REO
Thanks REO, looks like a nice setup. So does the platform for you planer just slide out the end and then slide back in the other way up?
View REO's profile
REO
#15 posted 12-28-2014 06:03 PM
the pivot point for the platform is centered and below the platform when the platform is upside down. and the planer is spaced so that when it is upright the table is flush with the surrounding surface. at this point the platform is below the pivot. the outfeed table has been removed from the planer
