Replacement Blade Guard
Forum topic by woodcravings posted 1577 days ago 2508 views 4 times favorited 6 replies Add to Favorites Watch
View woodcravings's profile
woodcravings
6 posts in 1625 days
1577 days ago
Topic tags/keywords: delta parts tablesaw
I decided to upgrade my Ryobi table saw and had been watching Craigslist in my area. I happened across an old Delta 34-410 contractor’s saw. Since it appeared to be in pretty good shape, I decided to pick it up. It was missing the blade guard, but I figured I’d just find a replacement. (I won’t “figure” this again – any future purchases will definitely include all the guards, etc.)
Well, now I’ve done some searching and managed to find a guard assembly for just under $90, but I still need to get some brackets to completely attach the guard assembly. Looks like the total will be around $150 – about what I paid for the saw. :)
Before I place my order, is anyone aware of good sources for cheap Delta replacement parts? I’m looking at ereplacementparts.com right now.
Thanks.
-- Neal
View Steve Maskery's profile
Steve Maskery
46 posts in 1581 days
#1 posted 1576 days ago
Hi Neal
Before you go out and buy one, have you considered making one? I made a SUVA-style guard for my tablesaw. I paid £10 (about $15) for some LDPE and a couple of quid for a Bristol Lever. The rest was scrap from the workshop.
It mounts onto the far right corner of the tablesaw and is supported by a shoe fixed to the top of the tablesaw rip fence. I’ve very pleased with its performance, and, because it is not mounted on the riving knife, I can do non-severing cuts like tenon shoulders, too.
http://www.workshopessentials.com
Since taking that photo I’ve swapped the V-shaped arm support for a U-shaped one, and I’ve added a top plate with a vacuum hole in it, but apart from that it is identical. If I made it again, I’d keep the pan-handle part shorter and increase the length of the pan, so that more of the rear of the blade is covered, too.
Cheers
Steve
-- The Complete Tablesaw - http://www.workshopessentials.com
View PurpLev's profile
PurpLev
7814 posts in 1845 days
#2 posted 1576 days ago
Steve, that is a fantastic solution even if one doesn’t NEED a replacement guard (but then again… it’s not surprising coming from you).
I’d definitely second Steve’s line of though – you don’t have to get ‘THE’ replacement guard, there are also 3rd party options, and homemade solution that will cost you much less – as seen in Steve’s solution, this is almost at no out of pocket cost.
View SteveMO's profile
SteveMO
54 posts in 1605 days
#3 posted 1576 days ago
Steve,
Nice looking guard. I’ve saved the pic for future reference. Another nice solution to someone’s problem. Nice work.
View rtb's profile
rtb
1097 posts in 1910 days
#4 posted 1576 days ago
Neal, Shop notes had a really good looking and very functional, much like Steve’s now is, going by his description, a few issues back I’ll post which one after I go out to the shop and locate it. Again its home made but the article includes planes. You may have to alter dimensions to fit your saw but still should be a lot better the the options you have right now.
-- RTB. stray animals are just looking for love
woodcravings
#5 posted 1576 days ago
Steve, thanks for the suggestion. Initially, I was looking at replacing the whole blade guard assembly, because I don’t have a splitter installed either and I was thinking I’d need to replace the whole assembly – that’s when I would need a couple of additional bracket off the back of the saw. However, I now see I can just get a replacement splitter and might not need to worry quite so much about the guard and brackets. Then I can look at building my own.
Does anyone know if I would have any problems with the currently available Delta splitter (1349941) on this older saw? It looks like it might just drop into the existing mounting bracket, but I didn’t know if I might run into some alignment problems.
-- Neal
View bke07's profile
bke07
1 post in 1576 days
#6 posted 1576 days ago
I have bought power tool and machinery parts from toolsandmachinery.com so you could try there or toolspartdirect.com also carries parts.
