Follow-up to mortise chisel hones inquiry
Forum topic by groland posted 02-22-2009 05:19 PM 1087 views 0 times favorited 4 replies Add to Favorites Watch
View groland's profile
groland
183 posts in 3437 days
02-22-2009 05:19 PM
Hi Folks,
Several days ago I posted an inquiry regarding small hones for sharpening mortise chisels. I have finally found on the Web, at Hartville Hardware, a wonderful tool and hardware supplier in Ohio, a set of the small hones for which I was seeking a source. I thought I would post this link in case others might be interested.
http://www.hartvilletool.com/product/10788
George Roland
View Francisco Luna's profile
Francisco Luna
943 posts in 3418 days
#1 posted 02-22-2009 07:45 PM
Interesting!...Thanks for the link.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View Emeralds's profile
Emeralds
143 posts in 3587 days
#2 posted 02-22-2009 08:14 PM
I’ve read that when sharpening either hollow mortise chisels, their augers or forstner bits one only sharpens the “inside bevel”. Is this information incorrect? If not, how do these stones allow you to do that?
Thanks
Joe
-- JMP
View John Ormsby's profile
John Ormsby
1288 posts in 3762 days
#3 posted 02-22-2009 08:29 PM
hollow chisel mortiser bits need to be sharpened with a special type of guide that is inserted into the center of the bit. These come in the various inside diameters of the bits. The sharpener has a hole in the center is at the proper bevel. This is slipped onto the guide and then turned so that the entire inside surface of the bit is sharpened symmetrically.
Here is a link that shows this sharpening system: http://www.toolzone.com/acatalog/info_RL635_9600.html
Also, I believe al types of drill bits are sharpened on the inside edges or tip. Never on the outside.
-- Oldworld, Fair Oaks, Ca
groland
#4 posted 02-22-2009 09:37 PM
Here’s another link to the bevel sharpener with centering cylinders:
http://www.woodcraft.com/product.aspx?ProductID=06V91&FamilyID=20129
I’ve ordered one of these that has two diamond abrasive “cones” without centering cylinders:
http://www.rockler.com/product.cfm?page=11153
Here’s an article showing the use of the little hones for prepping hollow chisel mortiser bits and chisels.
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=26261. It was this article that set me on a search for the little hones.
Articles I’ve seen on sharpening all emphasize sharpening the insides of the chisels and bits so as not to alter the sizes of the bore or chiseled mortise.
Anyone know of other sharpening hints or tools, bring ‘em on!
Best,
George Roland
