| Forum topic by Zelbar | posted 275 days ago | 646 views | 0 times favorited | 17 replies | ![]() |
275 days ago |
Topic tags/keywords: mitres I am having a small problem getting perfect mitre joints. I am using a Delta contaractors tablesaw with an Incra 1000 Mitre Jig and a Woodworker II blade I am getting a small gap at the out side corner. If I tighen it up in the jig for glueing I will get this gap at either one corner or two adjacent corners. The gap shows on both the top and bottom of stock. We are talking a small gap here but there is a gap and I am anal about that sort of thing. I have checked everything I can think of: Blade is 90 degrees to table top I can not see why they should not be perfect Any other thoughts on what to check or what my problem my be. Thanks -- With more power you can make toothpicks faster |
275 days ago |
Recently on the blog section Spaid enter a blog on this same subject the response was first rate, check it out….Blkcherry |
275 days ago |
I have a story at the link on the things I do to get better miters. I know this should be easier than it is but as it turns out, lots of stuf in woodworking is tougher than it seems like it should be….. -- Tom Hintz, www.newwoodworker.com |
275 days ago |
Hey all, the last time I encountered anything like this the miter gauge was loose in the miter slot. It does not take a lot of slop to get the “rocking” motion you are talking about. The longer the miter the more pronounced it becomes. -- If you need craft books - please visit our small business at http://www.wittywife.com |
275 days ago |
You say the stock is square…but is it flat? |
275 days ago |
Sounds like you might have a tiny bit of bow in the stock. Getting perfect miters is like marrying the perfect woman. It happens… but not very often. -- Charlie M. "Woodworking - patience = firewood" |
275 days ago |
Now that’s funny Charlie -- Scott - Chico California http://chicowoodnut.home.comcast.net |
275 days ago |
It could be that the blade is too thin. I use thick, industrial blades for cross cutting or mitering. They will not flex. Thin blades have a tendency to flex at the start of the miter thus leaving a small gap that will give the miter a curve look. -- Oldworld, Fair Oaks, Ca |
275 days ago |
I usually make rough cuts to get it close. Like a blades width, and then take a clean up cut for the final dimension. That way the blade thinkness won’t be a factor. If you do a lot of miters you might want invest in a miter trimmer like this on I reviewed: http://lumberjocks.com/reviews/14 They work great! -- Gary, East TX -- The longest journey begins with a single step. |
274 days ago |
Check your blade teeth. If you have a bent tooth or excessive gum buildup on a single tooth, it will throw off your cut. Using a miter sled will increase your accuracy but that will depend on how accurate you make it. To create a miter sled that can be 1/100 accurate, you should build one that is adjustable and can be fine tuned. Also if you make your own miter slot jigs, try adding a flat headed screw to allow you to remove any slop. Another sure fire way to get an accurate miter cut is to make a rough cut then fine tune it on your sander. The more test pieces you use the better the final results will be. Gaps suck in any joint and using a combination of different tools and techniques will get you closer to a professional and more accurate finished product. Never rely on one tool to get you to your final goal. -- "Love is like standing on wet cement, the longer you stay the harder it is to leave...and you can never go without leaving your prints behind..." |
274 days ago |
I didn’t see what kind of wood you are using. It sounds like you need to try a different blade. I’m not familiar with the incra 1000 mitre thing though they look handy…and spendy. I use a shop built sled when I have alot of mitres to make. -- Dan, Sterling Alaska, http://sullcon.homestead.com/ Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes! |
274 days ago |
All suggestions posted are great ones. Here is another one to add to your arsenal. I’ve always had better luck (and as Charlie indicated, it does involve luck) with a table saw. -- Gene |
274 days ago |
Think Douginaz might be on to the cause of the problem. It might not be any play in the miter guage slot of the table, but rather that the slot is not parallel to the blade. Common problem with contractor saws (no offense), they can have the table ever so slightly out of parallel to the blade. -- Gerry |
273 days ago |
I say don’t sweat the initial cuts – just do as close to 45 degrees as you can and then clean it up with a shooting board. -- Eric at http://adventuresinwoodworking.com |
273 days ago |
Did anyone think of the length of the pieces? I preach to my students that in most cases in woodworking exactness is more important than accurate measurements. Most of the time it is both, but there are critical dimensions that need to be exactly the same regardless of the size. For example in a mitered box, the two opposite sides need to be EXACTLY the same to get a perfect miter, along with the blade being set correctly at 45 deg, well duh. Think about it, who cares if your bookshelf is 35 7/8 or 36” as long as everything is square, flat and parallel. The key to making it that is a good setup and using a stop block to insure exactly the same length on each shelf. People that design the top shelf to overhang are asking for a little headache because now they can’t cut the top with at the same time as the shelves. Hope this makes sense. PM me if it doesn’t. Tooldad. |
273 days ago |
I did overlook you stated that the pieces were cut using a stop block. However if sawdust gets trapped, it can affect the length not enough to notice with the eye, but enough to screw you up on miters. Good luck in finding the solution. |
273 days ago |
Well I got it solved. I reajusted the back of the mitre gauge, there was some slight movement in the slot at the back end that I tightened up. After doing that I recalibrated the mitre gauge. After the tightening my digital angle finder showed 45.1 degrees. After some test cuts I ended up moving it to 44.9 degrees on my digital angle finder and everything is coming out as close to perfect as I can ask for. Have cut about 10 sets since then and they all look good. Thanks to everyone for the suggestions as it got me looking at other things. Earl -- With more power you can make toothpicks faster |
273 days ago |
Did you check to see if the blade is parallel to the fence. That blade runout could account for the small gap |
| Forum | Topics |
Woodworking Skill Share
2904 |
3923 |
256 |
943 |
222 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2371 |
LumberJocks.com Site Feedback
522 |
