Table saw gets loud under load...any ideas?
Forum topic by zackm032488 posted 12-24-2014 12:39 AM 1166 views 0 times favorited 10 replies Add to Favorites Watch
View zackm032488's profile
zackm032488
9 posts in 1602 days
12-24-2014 12:39 AM
Topic tags/keywords: tablesaw question milling
Hello everyone,
I’ve got a Ridgid R4512 that I’ve been using for about the past year without any problems. Earlier today though, I was feeding some 3/4 plywood through it and it all of a sudden changed to a much deeper sound and much louder.
I turned the saw off, then back on again and the sound was gone…until I started making another cut. As far as I can tell, it’s not affecting the performance of the saw, but it makes me uneasy when it sounds different a year into it.
Any ideas as to what might be causing it? And how to fix it?
Thanks.
10 replies so far
View splatman's profile
splatman
586 posts in 1639 days
#1 posted 12-24-2014 01:59 AM
Get a look at the motor (look thru the vent slots) while it’s running.
I had a Delta contractor’s TS that made a deeper, louder sound that usual, and the brushes were sparking and there was a burning smell. 12min of operation or so later, it went belly-up.
View DW833's profile
DW833
220 posts in 2123 days
#2 posted 12-24-2014 02:08 AM
I have the same saw. When I first got it, the belt was loose. I had to tighten. I would check it to make sure the motor hasn’t slid out of alignment. There are several post on LJ about how to tighten the belt if it is loose.
zackm032488
#3 posted 12-24-2014 02:13 AM
Thanks for the responses.
I should add, too…The sound doesn’t start until loaded, but it will continue after the cut is complete and there is no load. It only goes away if I turn the saw off, wait for it to stop, and then turn it back on.
View blackcherry's profile
blackcherry
3338 posts in 4063 days
#4 posted 12-24-2014 03:07 AM
Yea I check the belts first as address by DW833, with the saw off lift the motor up and then set it in the resting position check the belt tension with your finger. The belt shouldn’t give without firm pressure, then turn the belt by hand making sure no obstruction are hindering free movement. Take a close look with a flashlight to make sure the locking nut haven’t slip. I hope this is whats wrong easy fix if so just tighten up…best wishes BC
zackm032488
#5 posted 12-25-2014 11:55 PM
Well, I tightened up the belt and it seems to have helped. Only made one quick cut though.
I’ll put it through its paces tomorrow and see if it holds up.
zackm032488
#6 posted 03-18-2015 10:50 PM
A little update…I ordered a new belt over the weekend and I finally got it today. Holy smokes…cuts better than it did the day I bought it. I decided not to buy the Ridgid belt for $40 and instead found the exact same belt from an actual belt manufacturer for $2. That’s $38 left to spend on lumber.
View Ghidrah's profile
Ghidrah
667 posts in 1462 days
#7 posted 03-19-2015 12:15 AM
Thanks for the reminder, its high time I got new belts for my 953, 13 yrs is long enough yeah.
-- I meant to do that!
View knotscott's profile
knotscott
8180 posts in 3616 days
#8 posted 03-19-2015 10:16 AM
A little update…I ordered a new belt over the weekend and I finally got it today. Holy smokes…cuts better than it did the day I bought it. I decided not to buy the Ridgid belt for $40 and instead found the exact same belt from an actual belt manufacturer for $2. That s $38 left to spend on lumber.
- zackm032488
Thanks for the followup. Since so many folks own that saw, it’d be useful to a lot of them if you’d post the details of the where you got the belt and the belt #....
zackm032488
#9 posted 03-19-2015 04:24 PM
Yeah, the belt # is 140J6 and it can be found from various suppliers on the web. It is a 14” 6-ribbed J-series Poly V-Belt.
zackm032488
#10 posted 03-19-2015 04:28 PM
The 135J6 would probably also work. It is the same thing, but 13.5” instead of 14”.
