Wood Expansion/ Dissimilar woods
Forum topic by SteveKorz posted 278 days ago 765 views 1 time favorited 17 replies Add to Favorites Watch
View SteveKorz's profile
SteveKorz
2030 posts in 610 days
278 days ago
Topic tags/keywords: expansion wood expansion question
I have a couple projects in mind where I may glue up dissimilar woods together. Whether it’s edge gluing for a panel, or face gluing for a thick workbench top, I don’t want to worry about this ruining my project.
My question is, do I have to worry about the two dissimilar types of wood experiencing different rates of wood expansion and ruining the joint, or warping the project? Or, will the expansion difference be so minimal that I don’t have to worry about it?
Thanks in advance,
Steve
View cabinetmaster's profile
cabinetmaster
8590 posts in 454 days
278 days ago
What kind of woods are you talking about? I have taken and glued a lot of different woods together for cutting boards, tables and turnings and have had no problems with them. The woods I am talking about are maple, oak,hemlock,walnut, mahoganey, hickory, alder, etc.
SteveKorz
278 days ago
Well, I’ve been tossing the idea of a traditional oak workbench for some time. I think I would like to face glue 3/4 inch strips of 2 1/2 inch oak together for the top, with walnut stringers for the dog holes.
I’ve also thought of (on a different project) face gluing pine with hickory. This is the one (soft wood to hard wood) that I could imagine would give me the most trouble. The hickory would be the part of the workbench you would see and work on, the pine would just add weight and thickness, instead of the entire top being made of hickory.
25802 posts in 1296 days
278 days ago
Most wood expands and contracts on the width of the wood. As the tree grows. There is very little expansion or contraction on length. So if you are glueing edge to edge, you shouldn’t have any problems End to end might.
You need to also realize that not only might wood expand and contract it might also have an ability to be compressed. So if one board expanded into another the second might be able to be compressed when it could accept the extra movement.
The Wood Handbook from the US Forest service has more that you’d ever want to know about the properties of wood.
You can download it to your computer. They also have lots of other publications.
View Moai's profile
Moai
721 posts in 289 days
278 days ago
In a FWW magazine, a well known cabinetmaker says this:
”....I used quartersawn maple, but you might want to jazz up your project by using several different woods. That’s OK if the different species are, about the same density and will move with the seasons and wear at similar rates”
Fine Woodworking Magazine No.53, July/August 1985. Pag 65.
By the way, the article is about a Workbench project…
-- Francisco Luna, San Francisco Bay Area.
View John Gray's profile
John Gray
1753 posts in 781 days
278 days ago
Steve,
Wouldn’t it be easier to go to Boo’s and buy the top or parts of it? LOL
John
View mics_54's profile
mics_54
440 posts in 367 days
278 days ago
While it is true wood will shrink and expand more transverse to the grain it will indeed expand and shrink in it’s length. The amount that it shrinks or expands in it’s length is proportional to the total length of the piece. While 1/100 of an inch per foot maybe considered minimal expansion/contraction in a 6 inch length, if the piece of wood is 16 feet long the shrinkage or expansion would be nearly 3/16 inch. I recently experienced some rather disappointing results in a residential trim out project in a building with infloor heat that made the building humidity so low it broke almost every face frame joint and opened every trim joint in the whole project.
-- Dan, Sterling Alaska, http://sullcon.homestead.com/ Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
SteveKorz
278 days ago
Karson and doubthead- Thanks!!
John- I’ve thought about that… LOL
mics_54… Yikes… that’s a bummer…
View FJPetruso's profile
FJPetruso
163 posts in 606 days
277 days ago
A couple of key points in reducing the difference in the expansion of two types of wood in a project… would be to make sure that the different types of wood be brought into the shop well ahead of the start of the project so that the moisture level in the woods has had plenty of time to balance. You should also finish the interior of your project & seal up (as much as practicle) the interior as will as the exterior. Naturally it doesn’t have to look as pretty as the exterior but is should have some finish on it so as to reduce moisture absorbsion.
You know what it’s like to purchase 2×4 lumber at a hardware store only to have it twist while drying out at home. It’s because they store the wood OUTSIDE & only bring it inside just prior to selling the wood. Even if I have a project requiring 2×4s, I bring the wood into the shop, bundle it up into large bunches & bind it up with ratchet straps at both ends & the middle. After several weeks of drying inside, the straps are released & I find much less twisting, winding & warping of the lumber. A project like mics_54 told about is a good example of how important this acclimating time is.
-- Frank, Florissant, Missouri "The New Show-Me Woodshop"
mics_54
277 days ago
Fj you are right on about retail lumber sellers keeping “kiln dried lumber” out side untill its sold..it’s also shipped with minimal protection. Who knows what the moisture content is after it leaves the production facility. I let all lumber materials acclimate within the building it’s being installed. My project wasn’t due to that. It was due to the heat system and an exceptionally cold dry spell we had with no humidifier or air changes in the building. I have in 35 yrs as a trim carpenter never seen anything like this. The shrinkage occurred long after the material was “acclimated” , installed, stained and top coated.
View Sawdust2's profile
Sawdust2
1186 posts in 983 days
277 days ago
I’ve got a program that is a wood movement calculator.
If you’d like it send me your regular email address.
View pitchnsplinters's profile
pitchnsplinters
252 posts in 334 days
277 days ago
I’d be more concerned that they just wouldn’t get along. Arranged marriages can be full of trouble. I’d lay the two pieces on the bench and wait for a natural union. Quintessentially harmonious.
-- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits.
FJPetruso
277 days ago
Most of us won’t see the combination of an exceptionally dry season & a heating system that excells in drying out the house very often. So if we take reasonable care in the handling of our lumber prior to & while working on a project, we might have some shrinkage, but we probably will not encounter a once in 35 year exception like that.
View Gofor's profile
Gofor
109 posts in 683 days
277 days ago
Combining hickory and pine will cause different expansion rates in the two woods. I beleve you will have problems overlaying pine with hickory.
Oak and walnut are close enough that it should not cause a problem.
As for Kiln-Dried construction pine, it only has to be dried to below 20%. That isn’t even close for furniture work even if it isn’t exposed to the elements.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
Sawdust2
277 days ago
Just so I don’t get inundated, here is a direct link to the program
http://www.woodcentral.com/bparticles/bpindex2.shtml
It’s at the bottom of the page.
SteveKorz
277 days ago
Thanks Lee… !
View EEngineer's profile
EEngineer
275 posts in 509 days
276 days ago
Karson -
What a fabulous resource! As an engineer, I’ve been drooling over this document all morning! This is a great addition to my technical library. THX!
View ericlshlee's profile
ericlshlee
1 post in 274 days
274 days ago
hello,everybady, i find this is nice place to let us learn more about bench and reference,i working in a manufacturer in shenhen of china,i find what bench on this web is so nice and different with china plan. i think that i can produce it .i also tks this web to offer a balance to show me here. thanks if one who interesting to bench pls contact me ericlshlee@163.com eric.lee
