MKII and japanese chisels
« back to Hand Tools forum
Forum topic by mdraft posted 12-23-2014 04:17 PM 1035 views 0 times favorited 4 replies Add to Favorites Watch
View mdraft's profile
mdraft
26 posts in 1374 days
12-23-2014 04:17 PM
Hi everyone,
Has anyone here had any trouble fitting Japanese chisels in a MKII honing guide? I am considering picking up a few Japanese chisels, but want to make sure they will fit my guide first.
View sikrap's profile
sikrap
1121 posts in 3357 days
#1 posted 12-23-2014 10:35 PM
I haven’t had good luck using my MK II on ANY chisels, let alone the japanese ones. I love it for my plane irons, but I use an Eclipse style for chisels.
-- Dave, Colonie, NY
View djwong's profile
djwong
176 posts in 3218 days
#2 posted 12-24-2014 04:09 AM
I have used the MKII with japanese chisels to reset or repair the bevel. I am careful to tighten the jig evenly on the chisel. I don’t use the jig for everyday sharpening. An eclipse style jig might be faster. The problem is that the top of a japanese chisel is not necessarily parallel to the chisel back. Just be careful when you tighten the jig, and it should work fine. Once set, I have not had any slippage.
-- David W. Cupertino, CA
View cdarney's profile
cdarney
104 posts in 3029 days
#3 posted 12-24-2014 07:23 PM
I haven’t had any trouble using mine with my Japanese chisels. Careful tightening is very important.
View BubbaIBA's profile
BubbaIBA
387 posts in 2375 days
#4 posted 12-25-2014 06:30 PM
Japanese irons, chisels or plane, and honing guides are not a good match. Guides can be made to work but the operative word is “made”. On the other hand Japanese iron is very easy to sharpen freehand and it is a skill that once learned can be used with both Japanese and western iron.
Buy a couple of cheaper Japanese chisels, say a 13mm and a 18mm to learn on. Then once you are comfortable buy some good #1 or #2 White Steel chisels in the sizes you need. It can be the best of all worlds, you pick up a valuable skill and you have some of the best chisels available and even the cheap chisels can be pretty good chisels. BTW, I still use my first not too expensive Japanese chisels, not as much as the later ones but they are still used.
