Compucarve vs. Carvewright
Forum topic by 1978 posted 02-19-2009 06:25 PM 4859 views 0 times favorited 6 replies Add to Favorites Watch
View 1978's profile
1978
167 posts in 3811 days
02-19-2009 06:25 PM
Topic tags/keywords: question carving tool
Been looking at these two and have not found much on reviews. I am a woodcarver and wanted a new toy to play with. Does anyone own any of these or any thoughts on them, how they work, perform, durabilaty?
35148 posts in 4602 days
#1 posted 02-19-2009 07:38 PM
Cajunpen has one send him a PM. He might not see this post.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
View jm82435's profile
jm82435
1285 posts in 3944 days
#2 posted 02-20-2009 01:15 AM
I cannot answer your question, but here is something else to think about – you might also consider a cnc router. check out Spalms:
http://lumberjocks.com/jocks/SPalm/blog/2271 It is a different type of animal, but there is a lot of software out there to support cnc nowadays (look at Vectric for example)
http://www.vectric.com/WebSite/Vectric/vgallery/aspire/aspire_gallery.htm
I also have a little cnc router in my shop. my family calls it my spirograph because when I first got it together, I used spalms software he wrote to test it and ended up with lots of things that looked like the old spirograph toy designs.
-- A thing of beauty is a joy forever...
View Don Butler's profile
Don Butler
1092 posts in 3597 days
#3 posted 02-20-2009 01:32 AM
CompuCarve and CarveWright are the same, but CompuCarve comes from Sears, The CarveWright comes right from the manufacturer. I bought a CarveWright and I’m quite satisfied with it.
One needs to understand, though, these machines aren’t simple. You don’t just add wood and push a button. There’s a steep and long learning curve and there is a lot of maintenance. Just for example, think about a flexshaft working a router bit at 20,000 rpm. The manufacturer has a forum you can go on and ask around.
http://forum.carvewright.com/
Jump on over there. They’re friendly folks, for the most part.
d
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
View Chris Wright's profile
Chris Wright
540 posts in 3683 days
#4 posted 02-20-2009 01:33 AM
The Craftsman Compucarve and the Carvewright are identical machines. Carvewright makes them and for a short time licensed them to Craftsman, though now the no longer do. I’ve read reviews that are both good and bad about them. From what I’ve seen they are pretty easy to work with. I stopped by their booth at IWF in Atlanta last August, got to see one in operation. The results were less than stellar, the piece required a bit of finish sanding, though the rep said you can just go over it with a brush sander. One big downside though, you can only use their bits with it. Other CNC carvers use a standard router collet so you can use standard shank bits. CNC Shark looks real nice, and General is coming out with a new CNC router as well. One thing I do like about the Carvewright is the scanning probe. Anyway, that’s my 2 cents. Hope it helps.
-- "At its best, life is completely unpredictable." - Christopher Walken
View Sawdust2's profile
Sawdust2
1466 posts in 4289 days
#5 posted 02-20-2009 01:48 AM
I’m not a carver so I am not impressed with the machine.
That said, I have a friend who is a carver and, once he got the bugs and mechanical problems fixed, which took about 3 months and 2 returns to the factory, he says he is very happy with it. However, he had bought it at Sears and had to send it to CarveWright to get it fixed properly.
He does some interesting work with it. He’s still working on his learning curve but he is doing stuff that he likes and learns as he goes. (He’s retired so he can do that). I was impressed that you could scan a photo and it would easily convert to a carving on a piece of wood. Even put in the 3D aspects.
For a few hundred$$ more the one that Rockler sells does a cleaner job on the wood but I do not know anything about the programing.
View Mike Pientka's profile
Mike Pientka
129 posts in 3291 days
#6 posted 12-11-2009 09:20 PM
I bought a Shark Pro a year ago and summarized my experiences in this article I published on my website: http://www.original-approach.com/html/reviews.html
-- Engineer by day, Woodworker by night, Original Approach LLC, Windsor CO, www.original-approach.com
