Wolverine system question
« back to Woodturning forum
Forum topic by Rick Bailey posted 12-22-2014 03:15 AM 939 views 0 times favorited 3 replies Add to Favorites Watch
View Rick Bailey's profile
Rick Bailey
247 posts in 1292 days
12-22-2014 03:15 AM
I was sharping my tools with my new Wolverine system.
I did petty good :-).
My question is should I sand the burr off the top of the gouge after the grinding?
-- I'll bulid your dream,you tear it down.
3 replies so far
View crank49's profile
4030 posts in 2901 days
#1 posted 12-22-2014 03:48 AM
Use a hard Arkansas or ruby slip to hone it off.
The 2×4 x 1/8×1/2 Arkansa is easiest to find; check Amazon.
It’s rectangular 2” x 4” and the edges are rounded; one being 1/8” dia and the other being 1/2” diameter.
Made for honing the backs of gouges.
View TheDane's profile
5383 posts in 3593 days
#2 posted 12-22-2014 04:57 AM
Some use ‘slip stones’ (I have a set from Henry Taylor that I bought when I first started turning). They are about the same as the stones crank49 described above.
In truth, I’m not sure it is necessary. I have seen pros and cons on this … some say removing the wire/burr improves the cut, others say leave it because it will come off on it’s own when you are cutting.
View Wildwood's profile
2266 posts in 2064 days
#3 posted 12-22-2014 10:44 PM
I go right from grinder to turning burr gone in matter of seconds. I just touch up the tools and back to it! Do have some cheap diamond card files that use from time to time to touch up my tools and may use a piece of sandpaper between gouge flutes now and then.
Was looking at getting one of these stones to hone my tools, but never seem to get around to it.
At one time did use a wet stone and slips, homemade honing wheel and leather wheel on my lathe. Think did nothing more than insult my tools with wet & slip stones, and dull my tools with that homemade mess & compounds. Have not used that stuff in years,
-- Bill
