drive belts for Unisaw
Forum topic by mzimmers posted 12-21-2014 05:41 PM 1640 views 0 times favorited 16 replies Add to Favorites Watch
View mzimmers's profile
mzimmers
200 posts in 3939 days
12-21-2014 05:41 PM
Topic tags/keywords: link drive belt unisaw
anyone have any recommended sources? I could get them from Delta, but I’m a little hacked off at their customer service right now.
I don’t want to start a thread on linked belts, since they’ve been covered so much elsewhere, but if I were to go that route, how much length would I have to order? This is for a 7-year-old Unisaw.
Anyway, I welcome any recommendations.
-- M. Zimmers
16 replies so far
View waho6o9's profile (online now)
waho6o9
8207 posts in 2600 days
#1 posted 12-21-2014 05:50 PM
mzimmers
#2 posted 12-21-2014 05:55 PM
thanks. Is 5’ enough to replace all three belts? Sounds kind of short.
-- M. Zimmers
waho6o9
#3 posted 12-21-2014 05:56 PM
I don’t know as a Unisaw isn’t in my shop.
I’d take a string and measure against a belt and order accordingly.
4999 posts in 2517 days
#4 posted 12-21-2014 06:10 PM
I’d just get cogged V belts, preferably Goodyear. The size is AX 24, those have an outside length of 26” if you still want the link belts. At least that’s what my 2001 Unisaw takes. Good choice on ignoring Delta’s CS, that’s what they seem to be doing to us customers.
mzimmers
#5 posted 12-21-2014 06:18 PM
Thanks, Fred. If I get the cogged V belts, do I need a matched set like I (supposedly) do with the conventional belts?
-- M. Zimmers
View bigblockyeti's profile
bigblockyeti
5137 posts in 1744 days
#6 posted 12-21-2014 06:20 PM
mzimmers
#7 posted 12-21-2014 06:43 PM
Those look good Yeti. So, no concern about them having to match?
-- M. Zimmers
bigblockyeti
#8 posted 12-21-2014 06:51 PM
Quality belts are typically made to tight enough tolerances to negate the need for a “matched” set. This has been my experience. Goodyear and Gates as well as a few others can be reliably expected to be very close to each other. Working as a millwright in a recycling facility we had several machine ranging from tens to hundreds of horsepower using multiple belt drives and I never had a problem with goodyear AX, BX and CX belts even with 14 of them carrying 500hp.
#9 posted 12-21-2014 07:41 PM
No, they don’t have to be matched (as bigblockyeti explained).
mzimmers
#10 posted 12-21-2014 11:09 PM
OK, thanks, guys. I’ve got three on order from the big A…
-- M. Zimmers
mzimmers
#11 posted 12-25-2014 12:27 AM
Update: they came today, and they’re installed. Installation was a bit of a pain, though I could have made it somewhat easier by reading the directions more carefully the first time (you’d really think at my age I’d have learned to do that by now)...oh well.
Unfortunately, it didn’t seem to remove the “clunk” at motor startup as I’d hoped. The tension seems to be right (maybe a tiny little bit loose, but I’m out of adjustment room), so I don’t think the belts were the cause. Oh well, still a worthwhile experience.
Thanks again to those who advised on this.
-- M. Zimmers
View wbrisett's profile
wbrisett
203 posts in 2372 days
#12 posted 12-25-2014 12:44 PM
My 10 year old unisaw also makes that “clunk” sound at times. I’ve never been able to track down what causes it. It doesn’t happen every time, but often enough that I’ve wanted to figure out what it is and rectify it, but thus far haven’t been able to do that. If you ever figure it out (or if anybody else knows), I’d be curious to know how you fixed it.
#13 posted 12-25-2014 12:49 PM
Sorry, I didn’t realize you were chasing a clunk. Check here, down the page 7-8 questions and see if their advice helps.
wbrisett
#14 posted 12-25-2014 12:53 PM
Thanks Fred! I’ll have to look at that, I did check the belts, but not the stop collar.
mzimmers
#15 posted 12-25-2014 03:41 PM
Hey, Fred – I’d already seen that article, and checked the stop collar.
The pulley screws are a bit of a mystery to me. While I had the belts off, I tried to check the screws, but couldn’t find them. I did find some holes where screws might go (though I couldn’t tell whether they were threaded or not), but there were 4 of these (2 each on the first and third pulleys). I don’t think these are screw holes, though, and it’s kind of hard to believe that I’d be missing all 4 on a 7 year old saw that’s seen little use.
Anyway, the clunk is annoying (and causes me to flunk the nickel test) but not a showstopper; the saw still works fine. I think I’ll consider finding the cause to be a background task from here on out.
-- M. Zimmers
