Obfuscatory Sesquepedalianisms
« back to Coffee Lounge forum
Forum topic by Gene Howe posted 02-19-2009 01:44 AM 2532 views 0 times favorited 32 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
10479 posts in 3428 days
02-19-2009 01:44 AM
Topic tags/keywords: humor
I ripped this off another forum. Thought you all might enjoy and participate with your own.
Obfuscatory Sesquepedalianism #1 “There are a multitude of methodologies by which to divest the feline of its epidural enclosure”. In other words, there’s more than one way to skin a cat.
32 replies so far
View SST's profile
SST
790 posts in 4194 days
#1 posted 02-19-2009 02:49 AM
Just reading those words gives a simple guy like me a cephalalgia. -SST
-- Accuracy is not in your power tool, it's in you
View sry's profile
sry
147 posts in 3607 days
#2 posted 02-19-2009 02:49 AM
I can’t resist the classic:
One should multiply ascertain the dimension in question prior to engaging in any wood fiber severing activity
Measure twice, cut once
View lew's profile
lew
12061 posts in 3755 days
#3 posted 02-19-2009 03:04 AM
You guys are up the proverbial estuary with no visible means of motivation- Up S**T creek without a paddle
View Dan Lyke's profile
Dan Lyke
1520 posts in 4124 days
#4 posted 02-19-2009 07:31 PM
I think I’m gonna say my bit before the feces impacts the rotary impeller.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3874 days
#5 posted 02-19-2009 07:47 PM
A mass of consolidated mineral matter tumbling end-over-end is unlikely to collect lower-order plant material (A rolling stone gathers no moss).
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View fredf's profile
fredf
495 posts in 3709 days
#6 posted 02-19-2009 08:40 PM
If you guys don’t watch it you may find your self at the headwaters of the legendary tributary without the proverbial means of locomotion! (up a creek without a paddle)
fred
-- Fred, Springfield, Ma
16274 posts in 4218 days
#7 posted 02-19-2009 09:35 PM
Should you find it impossible to gain an advantage over your adversaries sheerly by virtue of your superior reasoning abilities, perhaps your cause would be better served by attempting to create confusion through the introduction of irrelevant factoids reminiscent of bovine fecal matter.
(If you can’t dazzle them with brilliance, baffle ‘em with bs.)
View SST's profile
SST
#8 posted 02-19-2009 10:09 PM
Oy!
Gene Howe
#9 posted 02-20-2009 08:23 PM
You guys are super word smiths.
Your posts have served to edify me greatly.
#10 posted 02-20-2009 08:32 PM
Heck, this is easy for me. Being on staff at a university, this is what every meeting sounds like when faculty are involved.
Peter Oxley
#11 posted 02-20-2009 10:20 PM
Commercial construction specification sounds like this too …
A device suitable for outdoor seating, the overall dimensions of which shall be 72” wide, 36” high, 20” deep. The seating section of the device shall consist of two main parts: the “seat” and the “back”, and shall be of wood segments which are each 5.25” x 1.75” x 72”. The seat shall be 18” deep, 1.75” high, 72” wide, and fixed five (5) degrees from horizontal with the lowest edge 16” above grade. The back shall be 20” high, 1.75” deep, 72” wide, and fixed five (5) degrees from vertical, perpendicular to the seat, and aligning with the lowest edge of the seat. The base and framework of the device shall be of wrought metal, and shall be affixed at grade level with not less than four (4) tamper-resistant bolts with a shear strength of not less than 1000 lbs each. The entire device shall be coated with an outdoor grade weather resistant paint, the seat and back shall match color chip #3300313, the base and framework shall match color chip #0017510.
... yeah, a park bench.
Peter Oxley
#12 posted 02-20-2009 10:40 PM
How about …
Refrain from discarding the human infant along with the soap and water mixture which was used to cleanse said infant.
Do not sequentially calculate quantities of domestic poultry prior to their emergence from their protective oval shells.
To each domestic canine belongs a single 24-hour period.
#13 posted 02-20-2009 11:43 PM
LOL! Good ones, Peter.
Gene Howe
#14 posted 02-20-2009 11:52 PM
CharlieM1958,
Been there, done that. Got the T-shirt and the snow globe. Eastern IL U, U of AZ.
Peter O,
Maybe this below should be stapled to those construction specs. and sent back to the ninny that wrote it.
Eschew obfuscation and do not engage in arrant pedantry of egregious sesquipedalianism.
Literal: Cut the B.S.
Dan Lyke
#15 posted 02-21-2009 12:04 AM
“Been there. Done that.” Wouldn’t that be something more like: Perambulated to that location. Participated in the specified activity. Obtained the appropriately branded textile.
showing 1 through 15 of 32 replies
