dw734 planer
Forum topic by Mojo1 posted 12-21-2014 11:52 AM 1370 views 0 times favorited 12 replies Add to Favorites Watch
View Mojo1's profile
Mojo1
262 posts in 2598 days
12-21-2014 11:52 AM
Been making a lot of cutting boards for lately and yesterday I have started having major problems with the DW734 not planing even. Seems to be about a .03 difference from one end to another. I spent some time adjusting the in and out feeds and still have the problem. Any one else have this problem? I am real close to buy another machine and use this one to get the wood close and better one to finish it off. I am looking at the DW735 and wonder if it would be much better? Kind of in a bind as I have several boards that I need done by Tuesday.
12 replies so far
View cracknpop's profile
cracknpop
282 posts in 2257 days
#1 posted 12-21-2014 01:26 PM
Sorry to hear about your troubles this close to your deadline. Is the difference occurring gradually along the entire length or is it the result of sniping and just occurring 1-2” from one of the ends. If the result of snipe, can you make your boards a little longer and then just cut off the end?
Another thought since you are this close to your deadline, perhaps there is another LJ in your area who would allow you to use their planer or drum sander.
Speaking of drum sander, if you are willing to spring for a new tool, you might consider a drum sander to finish them off.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
Mojo1
#2 posted 12-21-2014 11:37 PM
Well after not being able to fix the 734 bought a 735 today, Put it on my mobile table the old was on, built some feed tables on both ends and fired it up. Cuts like butter and all is good in the cutting board world.
View bigblockyeti's profile
bigblockyeti
4994 posts in 1629 days
#3 posted 12-22-2014 02:08 PM
Were you able to find out what was wrong with the 734?
View alittleoff's profile
alittleoff
534 posts in 1185 days
#4 posted 12-22-2014 10:11 PM
Glad to here the 735 works good. I just bought one last week but haven’t even plugged it in yet. May give it a try tomorrow if I get time.
Gerald
Mojo1
#5 posted 12-23-2014 11:08 AM
bigblock, I have not had time to figure it out, I did you use to rough out some walnut and maple yesterday then finish with the 735
alittleoff, I feel certain you will be happy with it !
crack, it seems to be towards the back and have about .025 dip , hard to figure how. I messed a little with it and the front roller is not giving pressure with a straight edge when the back one is, but that might be how it should be?
View Troy Cleckler 's profile
Troy Cleckler
384 posts in 1279 days
#6 posted 12-23-2014 11:38 AM
Sounds like it might me snipe to me. Not seeing the board can’t be sure. To keep the dip out you can run a short scrap butted up behind your work piece.
-- Troy. - Measure twice, cut once and fill the gaps....
Mojo1
#7 posted 12-23-2014 12:14 PM
Its not snipe, its almost not noticeable until I glue 2 parts together. It also is not at very end of the part.
View greenacres2's profile
greenacres2
313 posts in 2076 days
#8 posted 12-24-2014 05:26 AM
Your last post triggered a thought—almost sounds like either a sticky table, dull (or dulling) knives, or a combination of the two. Basically pretty simple machines, if it’s a little divot toward the outfeed end, means it’s feeding most of the way. Stop or drastically slow the feed for a few seconds—and you get that. Doesn’t take much sap on the 734 table to do that. (first-hand experience on a 733 doing that). Might be worth a look.
Dull knives behaved that way at times as well—i don’t understand the physics in that, so i can’t offer an explation. Just seems like they drag.
earl
Mojo1
#9 posted 12-24-2014 11:05 AM
I use paste wax on the table quite frequently and blades are very new but I had 2 or 3 kickbacks that might have ruined the blades. I have set and reset the tables but maybe still not getting them correct. When I get a chance I will look at the blades and the rollers and clean every thing.
View OSU55's profile
OSU55
1524 posts in 1898 days
#10 posted 12-24-2014 01:05 PM
Waxing is good, but I find I have to clean the table with MS or naptha to get all the sap off. I’ve had similar issues with a DW735 and it was a dirty table. Yet to have the feed rollers cause an issue.
View Randy_ATX's profile
Randy_ATX
874 posts in 2350 days
#11 posted 12-24-2014 01:40 PM
I was reading this because I have a 734. Maybe I’m just lucky but I’ve never had or heard of kickbacks on a planer? (two comments back). Are you planing endgrain?
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
Mojo1
#12 posted 12-26-2014 12:01 PM
Yes I was planing endgrain .The kickbacks were y fault, as I didnt feed it in as easy as I should.
