Polyline precision for smooth cutting? No faceting?
« back to CNC Woodworking forum
Forum topic by 007lab posted 12-21-2014 12:26 AM 1086 views 0 times favorited 2 replies Add to Favorites Watch
View 007lab's profile
007lab
22 posts in 1854 days
12-21-2014 12:26 AM
How many line segments in a wavy polyline are too many before one blows up their cnc machine?
I’m trying to draw a wavy line about 15” long. It can’t be faceted at all. Very organic looking.
So, I have two questions:
1-It’s easiest for me to draw the shape I want with the spline tool. Do I need to convert this line to a polyline when I send the dwg file to the cnc? (The CNC runs on Millwright 6.)
2-When drawing a 15” wavy spline I can convert it to a polyline and then specify the precision from 0-99. Roughly what number along that range would remove faceting, but not bog down the program?
It would be a lot easier to test this out on my own if the shop wasn’t 30 minutes away. So unfortunately I can’t walk over to the machine and run a test cut.
I’m running autocad for mac 2015.
2 replies so far
View changeoffocus's profile
changeoffocus
467 posts in 1524 days
#1 posted 12-21-2014 12:40 AM
I don’t know about your CNC but ACAD has a join command that turns segments into polylines.
I view the output to the CNC like sending a drawing to a plotter which provides a far more smooth line that the screen zoomed in. If you regen those lines will smooth out on the display as well. I always to curves and such as half of the drawing then mirror the image so they match perfectly.
Overlapping arcs and trimming is preferable to spline lines as spines tend to make the drawing size go up very fast.
Hope this helps.
View DS's profile
DS
2855 posts in 2327 days
#2 posted 01-02-2015 01:59 AM
Most CNC controllers can interpolate an arc line just fine (no facets at all)
I have yet to encounter a CNC machine that could manage ACAD splines. I’ve always had to convert them to arcs. (No g-code equivelent for splines)
Polylines allow you to make a continuous cut without the tool lifting out of the workpiece after each segment.
Also, as far as limits to the number of facets, I’ve found CNC machines to be very patient with the minutiae and diligently execute each and every line of code, usually without blowing up.
Happy new year
