Raised Panel Router Bits
Forum topic by Straightpiped posted 02-18-2009 02:34 PM 1200 views 0 times favorited 9 replies Add to Favorites Watch
View Straightpiped's profile
89 posts in 3420 days
02-18-2009 02:34 PM
Does anyone have these bits in 1/4” shank, or do I just need to step up and buy a 1/2” shank router?
-- T. Nelson
9 replies so far
View whit's profile
246 posts in 3906 days
#1 posted 02-18-2009 02:44 PM
A raised-panel bit in a 1/4” shank is a tough order. You might find mini versions but if you’re looking for a bit for full-sized panels, you’ll probably have to get 1/2”. There’s a lot of torque with the larger bits and a 1/4” shank becomes a weapon. And the bit becomes a projectile.
-- Even if to be nothing more than a bad example, everything serves a purpose. cippotus
#2 posted 02-18-2009 02:45 PM
Kinda what I was thinking.
-- T. Nelson
View klpete45's profile
15 posts in 3323 days
#3 posted 02-19-2009 02:46 AM
I look at my raised panel bit and I would be afraid to use it if it only had a 1/4” shank. I mean we are talking about a 3 1/4” diameter hunk of heavy tungsten spinning at thousands of RPMs. This thing intimidates me now, I can only imagine how I would feel if I had to look at that giant head on a puny little shank! Seriously, this is the kind of bit that 1/2” routers were invented for – even if you could find a 1?4” bit I would advise you not to buy it. IMO
-- Klpete45, Oklahoma
View FEDSAWDAVE's profile
293 posts in 3361 days
#4 posted 02-19-2009 03:18 AM
Real tough order. To easy to snap. Router bit manufactuers are stopping at a certain diameter for the sake of safety. Don’t need some raised panel flying towards your head…
-- David,
View mrtrim's profile
1696 posts in 3809 days
#5 posted 02-19-2009 03:49 AM
id recommend a 1/2 shank and a really good quality bit , about 3 hp router that has varible speed . i promise your life will suck if you have to sand router burn off a bunch of raised panels
View 8iowa's profile
1569 posts in 3690 days
#6 posted 02-19-2009 03:57 AM
A large diameter raised panel bit requires a lot of torque and a speed of around 10,000 rpm is usually recommended. This is actually a better application for a shaper than a router. Our great an useful PC 690’s are just not up to the task.
#7 posted 02-19-2009 04:06 AM
PC690’s at 1 3/4HP..probably not. PC 7518, 7519, 7538, 7539 at 3 1/4 HP…as good as a shaper.
-- David,
View scarpenter002's profile
605 posts in 3834 days
#8 posted 02-19-2009 05:04 AM
If you can’t upgrade to 1/2” router, you might try a verticle raised bit.
-- Scott in Texas
#9 posted 02-19-2009 02:10 PM
Thanks guys,
Bought a 1/2” Router.
-- T. Nelson
