Air tight seal on humidor?
Forum topic by SawdustWrangler posted 02-18-2009 05:03 AM 3122 views 0 times favorited 4 replies Add to Favorites Watch
View SawdustWrangler's profile
SawdustWrangler
91 posts in 3268 days
02-18-2009 05:03 AM
I would like to build a moderate humidor and the only question I have is what is the best way to achieve an air tight seal? I have a metal travel humidor I’m currently using and it has a gasket type seal. Thanks guys!
-- Chris, South Carolina
View childress's profile
childress
841 posts in 3412 days
#1 posted 02-18-2009 06:29 AM
Most of them have a lip of spanish cedar (1/4” thick) that hangs down from the lid. When you close it, the lip fits into the lower portion of the box. I have also seen the lip in the lower portion of the box, and when you close the lid, the lip fits into the lid. Hope I explained this right. Check out my projects and see the humidor I made and you will know what I’m trying to say.
-- Childress Woodworks
SawdustWrangler
#2 posted 02-18-2009 09:37 AM
Nice, ty
View JimmyC's profile
JimmyC
106 posts in 3272 days
#3 posted 02-18-2009 08:05 PM
Also , as far as cigars are concerned, and I am an aficianado, humidors shouldn’t be kept air tight for long term. They should be opened occasionally to let fresh air in, or to take a cigar out :>).. For long term storage of a fairly large amount of cigars I use an ice cooler, which seals tight. and a smaller humidor. The smaller humidor seals just as it was explained above.
Jimmy
-- -JimmyC...Clayton,NC- "Just smile and wave boys, smile and wave"
SawdustWrangler
#4 posted 02-18-2009 09:55 PM
Good point Jimmy. I usually keep a dozen or less on hand. Once golfing weather returns, it will be opened quite frequently. ;-)
