Joint for edge gluing cabinet top
« back to Joinery forum
Forum topic by Joel_B posted 12-19-2014 08:00 PM 927 views 0 times favorited 3 replies Add to Favorites Watch
View Joel_B's profile
341 posts in 1313 days
12-19-2014 08:00 PM
Making a night stand out of redwood boards.
For the top should I just leave the edges flat and glue together or run through the router table with tongue and groove bit? What router bit would be best? What is a good clamping system for this? I don’t have a real work bench just a table with a top that isn’t that flat, could put a piece of MDF on it to make it flat.
-- Joel, Encinitas, CA
3 replies so far
View PhillipRCW's profile
462 posts in 1196 days
#1 posted 12-19-2014 08:22 PM
You can make an improvised router table for like $10 bucks if you have two saw horses. Search lumber jocks for router tables. MDF or plywood base, one board screwed into place for a pivot and a clamp to hold the other end to the base. You use the router to cut a hole and screw it under the “table.” I believe Home Depot has a router bit set for tounge and groove. You could just rabbet out the edges on one side and cut a mortise down the length of the opposing side.
-- Phillip- Measure twice, cut onc.... Hey look, it's rustic.
#2 posted 12-19-2014 08:35 PM
I already have a good router table, just lacking on the workbench.
I was thinking something like this:
View pintodeluxe's profile
5592 posts in 2745 days
#3 posted 12-19-2014 09:13 PM
No need for joinery on long grain glue joints. Just joint them square and glue them up. Pipe clamps top and bottom will help keep the panel flat.
If you’re concerned the workbench isn’t flat, you can use clamping cauls as a little insurance that your panel will be flat.
If you have a planer, do the glueup in stages. For instance a 24” wide glueup made from 6” wide boards could start by gluing two pairs of boards together. After the glue dries, plane the two resulting 12” planks smooth. Then glue the two planks together. That way you only have one glue line to sand.
