Garage Insulation question
Forum topic by Vactet posted 12-18-2014 08:24 PM 1031 views 0 times favorited 12 replies Add to Favorites Watch
View Vactet's profile
Vactet
9 posts in 1257 days
12-18-2014 08:24 PM
Figured I would throe this question out there to the community.
I live in Fl so my garage can get rather hot at times. I have been looking at ways to insulate it as best as possible.
the major culprit is the garage door of course.
Saw this kit at Lowes for insulating the garage door. Comes with large pieces of what looks to be Styrofoam.
Anyone had any experience with this kit? Would love to get an idea of its effectiveness before investing in the cost.
If it works as good as advertised then its worth the cost but its pricey without some feedback first.
Thanks folks.
12 replies so far
View JoeinGa's profile
JoeinGa
7736 posts in 2005 days
#1 posted 12-18-2014 09:02 PM
Compare the price of that “kit” with the cost of the 4’ X 8’ sheets of Styrofoam. You can buy it in several different thicknesses and cut it yourself. HD has some sheets in 2” thick for $36 per sheet and also 3/4” thick for $17 per sheet. It’s pink but who cares about the color so long as it works.
I used the 3/4” stuff on my garage door panels. Cut to fit with a razor knife and held it in with construction adhesive. It was still on there when we moved from there after 8 years.
Vactet
#2 posted 12-18-2014 10:09 PM
Fair point. The kit is like 70 bucks. Quiet a markup. I rarely go to HD. Lowes is closer and the staff of the closest HD sre less than pleasant to deal with.
But ill go check it out. Does seem a better price for a bit more work. But who here is afraid of a bit of work.
thanks.
View Rayne's profile
Rayne
864 posts in 1537 days
#3 posted 12-18-2014 11:29 PM
I bought 2 sets from Groupon before, $36 each and they work great. It’s a bit chilly right now, but in my garage, it’s not nearly as bad. Same with during summer; when it’s humid and hot, it’s no where near what it is outside.
View MT_Stringer's profile
MT_Stringer
3168 posts in 3229 days
#4 posted 12-18-2014 11:45 PM
I had that stinking metal door, one that faces into the western sun in the afternoon. I tried filling it with insulation cut from a 1 inch 4×8 sheet. Eventually, I replaced the door with an energy efficient door. Much better.
View dhazelton's profile
dhazelton
2767 posts in 2294 days
#5 posted 12-19-2014 12:28 AM
I would think a foil faced radiant barrier would be more useful than just plain open celled foam. For what it’s worth…
View jimr1cos's profile
jimr1cos
31 posts in 1884 days
#6 posted 12-19-2014 04:25 AM
I cut panels of the 1 in blue extruded foam to fit each metal rectangular section. Glued them in with foam adhesive and filled the gaps with aerosol foam. Works well here in Colorado, both summer and winter.
View Moron's profile
Moron
5032 posts in 3891 days
#7 posted 12-19-2014 04:36 AM
i once had a teacher who put a sticker on the chalkboard for every well done deed
my mom put pictures on the fridge with magnets
i have not a magnet, nor a sticker left
just because a bazillion dumb ass and or old people failed, doesn’t mean you have to
Moron
#8 posted 12-19-2014 04:37 AM
buy a new door
or make one ?
View ChefHDAN's profile
ChefHDAN
1062 posts in 2847 days
#9 posted 12-19-2014 11:04 AM
I did my door with the 3/4” foil faced foam sheeting that I bought in 4’x’8’ sheets and used expanding poly foam to fill the voids in and around the U channel structures. I was tempted to go with the thicker ridgid foams but read an article somewhere about the coil spring strength vs. added weight to the door. I have living space above my garage and the door faces east, and after adding the foam I found a 10 to 15 degree improvment in the space against exterior temperature, and am able to get it sweatshirt and jeans warm in the winter when we have 30*f or so outside, using a couple of ceramic heaters and a small fan. Biggest problem I’ve found is how to get the damn concrete slab warm, even in insulated boots my feet are freezing after a few hours..
View Gentile's profile
Gentile
303 posts in 1816 days
#10 posted 12-19-2014 03:05 PM
I went with the foam sheets on my garage door. Home Depot was where I bought them. I cut them on my table saw, messy, but accurate. Each panel was made with two pieces, a large one and a smaller strip. The styrofoam doesn’t bend vey well. The door sections had two different heights of the panels
I didn’t need to use any adhesives as the styro fit in the channels of the door panels.
Amazingly, it added weight to the door, who would of thunk?
-- "I cut it twice and it's still too short"
Gentile
#11 posted 12-19-2014 03:11 PM
View bondogaposis's profile
bondogaposis
4727 posts in 2349 days
#12 posted 12-19-2014 04:20 PM
ChefHDan, I had the same problem but solved it by insulating the floor w/ Harbor Freight anti fatigue mats. I did all of the walk ways and standing areas in my shop and it has worked well for several years now. I started out by doing the standing areas in front each machine, then eventually connected them all together.
-- Bondo Gaposis
