Leveling bandsaw throat plate to the table
Forum topic by daviddoria posted 12-18-2014 04:45 PM 1641 views 0 times favorited 8 replies Add to Favorites Watch
View daviddoria's profile
daviddoria
67 posts in 1901 days
12-18-2014 04:45 PM
I have the 14” Porter Cable bandsaw (PCB330BS). The plastic throat plate insert is lower than the table. There are no leveling screws in the cut out of the table. Would you guys just shim something like this to get it level? If so, what do you use? I tried using some masking tape, but it’s quite hard to do because of how thin the outer lip is (see the attached picture).
Is there a better way to go about this that I’m not thinking of?
Thanks,
David
8 replies so far
View Tommy Evans's profile
Tommy Evans
146 posts in 2136 days
#1 posted 12-18-2014 04:51 PM
Place 3 or 4 drops of hot melt glue around on that narrow lip.
To keep the glue from sticking to the insert, use vaseline or something like that on the insert.
Press the insert in while the glue is still wet.
Hope that helps.
peace, T
View bigblockyeti's profile
bigblockyeti
5085 posts in 1683 days
#2 posted 12-18-2014 04:58 PM
I turned a few from thick acrylic for my Grizzly bandsaw, little tricky at first, but after a couple that were trash, I had the procedure down and they work great.
MrUnix
6576 posts in 2161 days
#3 posted 12-18-2014 05:50 PM
I make my own on the lathe as well.. for my Delta band saw as well as my Delta scroll saw (which uses the same size inserts). Hot melt glue is also a great idea.
daviddoria
#4 posted 12-18-2014 06:12 PM
Thanks all! I was actually thinking about hot melt glue, but I didn’t know how to not glue the insert to the saw. I’ll definitely try the vaseline and see how it goes.
David
runswithscissors
2724 posts in 1987 days
#5 posted 12-19-2014 12:37 AM
Hotmelt glue doesn’t stick so tenaciously that you couldn’t pry it off when need
View Picklehead's profile
Picklehead
1041 posts in 1892 days
#6 posted 12-19-2014 12:47 AM
3 blobs hot melt, no vaseline, push it down til it’s level. If it isn’t just how you want it, rip it off and repeat.
-- You've got to be smarter than the tree.
View ChefHDAN's profile
ChefHDAN
1047 posts in 2812 days
#7 posted 12-19-2014 11:10 AM
I’d reccomend going with a ZCI insert like these, The white ones work with my Ridgid BS, and they fit much better than the stock ones as well as being ZCI.
View macatlin1's profile
macatlin1
78 posts in 2905 days
#8 posted 12-19-2014 01:21 PM
If you need to get the hot melt off, just use some alcohol and the bond breaks almost instantly.
