How do you heat your Garage shop?
Forum topic by AndyMc posted 12-18-2014 01:13 AM 1871 views 0 times favorited 21 replies Add to Favorites Watch
View AndyMc's profile
10 posts in 1508 days
12-18-2014 01:13 AM
I realize this question has been asked many, many times, but I live in a somewhat “warm climate” (read- SF Bay Area). For the most part, we rarely go below say 40. That , I’m not afraid to say, is cold to me :) What types of heaters to you all use? Space, electric, propane, natural? My garage is ‘mostly insulated’. I lean toward, inexpensive & easy, but not afraid of spending a few bucks, if it makes me more comfortable.
-- "Get busy livin' or get busy dying" Shawshank
21 replies so far
View JoeinGa's profile
7733 posts in 1943 days
#1 posted 12-18-2014 01:21 AM
I use a 220volt electric. Bought about 2 years ago on E-bay for less than $100 shipped to my house. Welded a small roll-around base and I have it on a 25ft extension cord so I can move it around and have it pointed towards me near the area I’m working in. If I crank it up to “Hi” and leave it run. it will get my 24 X 36ft shop up to over 70degrees in about an hour.
View Jim Finn's profile
Jim Finn
2641 posts in 2858 days
#2 posted 12-18-2014 02:24 AM This is what I use here in Texas. It is a bit colder here than in the bay area. ( I lived in Sunnyvale for a few years.)
View Joseph Jossem's profile
Joseph Jossem
492 posts in 2204 days
#3 posted 12-18-2014 02:39 AM
I have had to put on a sweater in the mornings here hits lows 70s does that count!
17780 posts in 1793 days
#4 posted 12-18-2014 03:05 AM
I use a 1500 watt ceramic heater with a blower most of the time. I keep it set on the lowest setting all the time. Keeps it around 40 in there. Then I turn it up about 30 min. before I want to work. When it gets really cold I will plug in a second one, but then I start to have problems with breakers. Have to remember to turn off the heater before turn on major tools or else pop. In Mo it gets down to 0° several times each year. I usually avoid those times.
View bigblockyeti's profile
5060 posts in 1657 days
#5 posted 12-18-2014 03:16 AM
I use a 40000 btu natural gas Dayton heater in my shop, much like the one pictured, only a little smaller. Keeps the floor clear and require no preparation like a wood stove would, despite the fact that’s what I’d rather have.
View Jimthecarver's profile
1124 posts in 3721 days
#6 posted 12-18-2014 03:30 AM
I use a pellet stove….they are super.
View Heywood's profile
46 posts in 1384 days
#7 posted 12-18-2014 03:41 AM
Radiant in floor heating. I keep it set at 58 and I warm up pretty quick once I get busy.
View Woodmaster1's profile
905 posts in 2523 days
#8 posted 12-18-2014 04:16 AM
I have 50,000 btu bigmaxx heater so far it has done a great job. The coldest it has been is 25. December 27 it is going to be 9 degrees, that should be a good test.
View OSU55's profile
1580 posts in 1926 days
#9 posted 12-18-2014 12:30 PM
A lot depends on the size of your work area, are all the energy sources you listed already hooked up and available, where and what type of finishing do you do, and do you use your shop daily?
My area is a 24×28 attached garage space fairly well insulated, in MO where it can get below 0°. I use a small 120V 1500w ceramic heater plugged into a real Lux thermostat for good temp control. I leave it set on 63° all the time, and I’m usually in there an hour or 2 a day at the least. If you use the shop daily and it’s fairly well insulated keeping things warmed up is about the same cost as heating up/cooling down, and heating everything up quickly takes a lot more heater (a lot more $’s up front). I mention finishing because I don’t want an open flame anywhere in a room where I’m using solvent finishes with explosive vapors – this includes solvent poly brushed or wiped on – on bigger projects.
View buildingmonkey's profile
242 posts in 1484 days
#10 posted 12-18-2014 12:44 PM
I have a 50,000 btu furnace I got from my local hvac guy. He took it out of a house they added onto so it wasn’t big enough anymore. It is in the corner of the building, and 3 years ago I put a new AC in the house and put the old one on the shop. Nice to have heat AND cool in your shop.
-- Jim from Kansas
View MrFid's profile
874 posts in 1840 days
#11 posted 12-18-2014 12:46 PM
I just fart a lot.
-- Bailey F - Eastern Mass.
#12 posted 12-18-2014 12:59 PM
Best heat source there is!
View Blackie_'s profile
4856 posts in 2449 days
#13 posted 12-18-2014 01:35 PM
Like Jim, I am in central Texas, I use this Stanley heater to warm my stand alone shop.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at
View BinghamtonEd's profile
2286 posts in 2306 days
#14 posted 12-18-2014 01:51 PM
Does body heat count? My shop was down around 35 the other day, and felt cold. Every time I have to open the garage door to get the snow blower out, the temperature plummets. I have a nice lined hoodie from LL Bean that I will wear for the first 10 minutes or so. Once I get to some hand tool work or moving lumber around, I sometimes warm up enough to get by without it.
View Lazyman's profile
1820 posts in 1323 days
#15 posted 12-18-2014 02:29 PM
I friend of mine loaned me a Soleus 12,000 BTU portable A/C with heater function. It runs on standard 110v outlet. I borrowed it for use in my uninsulated garage during the Texas summer but I have found that the heater is great for the cool days too. For heat, this one acts as a heat pump, basically running backwards. I also bought a 1500 watt shop space heater that I have hanging over my bench for those really cold days to make a warmer spot.
