Jet Bench Top Planer question
Forum topic by Charlie75 posted 12-17-2014 08:40 PM 928 views 0 times favorited 7 replies Add to Favorites Watch
View Charlie75's profile
Charlie75
310 posts in 2174 days
12-17-2014 08:40 PM
I have a question about my jet planer. When I in feed a piece of lumber often the rollers that pull it through start to slip and I get snipe in the middle of my lumber. I assume this to be a problem with the rollers themselves. My question is what can I do if anything. Are these rollers replaceable or fixable? Some time in the future I plan on replacing the planer but it’s not in the budget right now.
Thanks in advance.
Charlie
-- Charlie75, Alto
7 replies so far
View jmartel's profile
jmartel
7687 posts in 2059 days
#1 posted 12-17-2014 08:44 PM
Clean the rollers and wax the bed of the planer. That should help.
View pintodeluxe's profile
pintodeluxe
5569 posts in 2723 days
#2 posted 12-17-2014 10:00 PM
DULL BLADES! Yep, when the blades are dull, the rollers are trying extra hard to push the stock through. There is extra resistance so the rollers slip and leave black marks or divots.
In thousands of feet of lumber, I have never actually had to clean my rollers. Waxing the bed will help for a short while, but replacing or sharpening the blades is the fix.
Best of luck with it.
Charlie75
#3 posted 12-17-2014 11:40 PM
Thanks guys. Makes sence that dull blades might do it. I really should replace the blades. they have been sharpened two or three times.
-- Charlie75, Alto
View Dave G's profile
Dave G
331 posts in 1957 days
#4 posted 12-18-2014 12:11 AM
Don’t skip over that comment about waxing the bed. That gave me double blade life all by itself. I draw a few lines on the plate with a bar of beeswax every time I plane and improved the skipping problem.
-- Dave, New England - “We are made to persist. that's how we find out who we are.” ― Tobias Wolff
Charlie75
#5 posted 12-18-2014 01:26 AM
Don t skip over that comment about waxing the bed. That gave me double blade life all by itself. I draw a few lines on the plate with a bar of beeswax every time I plane and improved the skipping problem.
- Dave G
Thanks Dave. I’ll give it a hot. Will parafin work?
-- Charlie75, Alto
Dave G
#6 posted 12-18-2014 09:27 AM
I’m sure it will. I think soft paste wax would not work as well because it would rub off right away. As long as you can see the lines you draw with the candle or whatever then you’re getting lubrication.
I started using beeswax for three reasons: 1) I had a bunch leftover and I don’t want to waste it and 2) It’s a proven wood finishing compound 3) I like the smell
runswithscissors
2657 posts in 1934 days
#7 posted 12-19-2014 12:48 AM
Dry lube (various brands) also is good for making tables slippery. Don’t get it on your feed rollers, though.
