Butterfly Inlay
Forum topic by Marshall posted 12-17-2014 06:36 PM 1309 views 0 times favorited 12 replies Add to Favorites Watch
View Marshall's profile
Marshall
151 posts in 2289 days
12-17-2014 06:36 PM
Hi all,
First, thanks to everyone that has commented on my previous threads as I’m working through my table project.
I’ve been practicing with a butterfly template before I use it on my table top, and this is my latest effort.
Any suggestions for eliminating the small gap on the right side? Could it be because the bit isnt centered perfectly?
Thanks
-- Marshall - http://mcomisar.tumblr.com
12 replies so far
View jmartel's profile
jmartel
8276 posts in 2384 days
#1 posted 12-17-2014 06:54 PM
Could be an uncentered bit, could be just a bit of tolerance stacking to where it ends up with a slight gap. Either way, that small gap will be filled in with sawdust and glue and you won’t be able to tell when it’s done.
Gerald Thompson
1141 posts in 2469 days
#2 posted 12-17-2014 09:38 PM
I would use hide glue and sawdust. That is if I ever were to make a mistake. :)
-- Jerry
View pintodeluxe's profile
pintodeluxe
5815 posts in 3047 days
#3 posted 12-17-2014 09:54 PM
I have found that even the templates have slight variations to them. Mark your template side “A” and side “B”, then mark the inlay as you cut it. It may fit better in the same orientation.
Your inlay looks pretty good. I agree that the bit-centering cones help.
Some of my routers cut better inlays than others. The better routers have very little play in the plunge mechanism.
Good luck.
Marshall
#4 posted 12-18-2014 03:12 PM
Thanks guys.
View shipwright's profile
shipwright
8184 posts in 3032 days
#5 posted 12-18-2014 03:26 PM
That fit looks pretty good to me too. We can become obsessed with tiny details when working on a project that no one would EVER notice in a finished project.
That said, if you need the perfect fit, you can make the inlay piece slightly conical (a degree or two) with a chisel ot by sanding carefully. If you do it right it will just give you the tiny gap on the bottom instead of on the top. Structurally it will be just as good.
TheWoodenOyster
1317 posts in 2169 days
#6 posted 12-18-2014 03:36 PM
I’m with shipwright on the slightly sloped sides. That should give you a little tighter fit to close those gaps.
Remember, we are the only people who see that gap. Glue would likely close it up fine and I’m pretty sure a non-wood dork would never see much less comment about that. It looks pretty good to me.
-- The Wood Is Your Oyster
jmartel
#7 posted 12-18-2014 03:39 PM
Correct me if I’m wrong, since I’ve never used an inlay template (just freehand it usually), but doesn’t the template method leave you with the exact fit? Tapering the bottom after cutting wouldn’t fix the issue of a small gap at the top? You would need a slightly smaller diameter bushing. Maybe the next size down and a few layers of tape would work?
Marshall
#8 posted 12-18-2014 03:58 PM
Thanks guys. I tend to slave over tiny details while my wife is like wtf it looks fine :)
Reminds me of a couple chris schwarz blogs:
http://www.popularwoodworking.com/woodworking-blogs/chris-schwarz-blog/dont-work-for-the-pets-and-pests
http://blog.lostartpress.com/2013/04/19/on-technical-perfection/
View RRBOU's profile
RRBOU
176 posts in 2526 days
#9 posted 12-18-2014 04:04 PM
I like to take a piece of tape and wrap it around the bushing for cutting the inlay or the pocket depending on the template. This gives it a very slight over size. Then sand a taper on it and insert it in the pocket. This will get rid of the small gaps. PIA Yes but I hate gaps.
-- If guns cause crime all of mine are defective Randy
Marshall
#10 posted 12-18-2014 04:36 PM
Thats not a bad idea. I might give that a try.
117416 posts in 3811 days
#11 posted 12-18-2014 04:42 PM
Good tips,there’s always more than one way to solve a problem.
View oltexasboy1's profile
oltexasboy1
250 posts in 1938 days
#12 posted 12-18-2014 04:55 PM
If I could get one that close to perfect I’d kiss a horse ,in the mouth.
-- "The pursuit of perfection often yields excellence"
