Flush trim finger joints
« back to Joinery forum
Forum topic by ChuckH posted 12-17-2014 01:02 PM 2316 views 0 times favorited 21 replies Add to Favorites Watch
View ChuckH's profile
70 posts in 1701 days
12-17-2014 01:02 PM
Topic tags/keywords: finger joint
I’ve just made my first finger joint box, and the fingers are proud all around. My first inclination is just to run the whole thing on the jointer; it’s 4.5 in tall, so plenty of room. Anything wrong with that, or I should looke out for? My other options are trim them on the TS but I’m worried about scratching up the box sides, or not having it just square to the blade. I really don’t want to flush cut them all with a hand saw.
21 replies so far
View Woodbum's profile
804 posts in 3000 days
#1 posted 12-17-2014 01:08 PM
Sand them flush? Either power or hand depending on how proud they are. I’ve done this dozens of times with a ROS, hand held belt sander, stationary sander etc. and by hand or both.
-- "Now I'm just another old guy wearing funny clothes"
#2 posted 12-17-2014 01:14 PM
Good idea, don’t know why I didn’t think of it. I may have been thinking at 1/8” they’d be too proud to sand, but mostly I hate sanding, so tend not to think about it.
View RibsBrisket4me's profile
1554 posts in 2440 days
#3 posted 12-17-2014 01:16 PM
Yep, those will sand flush in a jiffy!
View BinghamtonEd's profile
2286 posts in 2304 days
#4 posted 12-17-2014 02:17 PM
Block plane?
#5 posted 12-17-2014 02:25 PM
Maybe after Christmas if Santa brings me one ;)
View ADHDan's profile
800 posts in 2043 days
#6 posted 12-17-2014 03:10 PM
I’ve sanded proud fingers flush, and I’ve trimmed them with a flush cut bit on the router table.
-- Dan in Minneapolis, woodworking since 11/11.
View distrbd's profile
2252 posts in 2381 days
#7 posted 12-17-2014 03:27 PM
There’s nothing wrong with leaving the fingers proud if they complement the design,just sand the fingers even but leave them proud and decide for yourself if you like the way it looks ,if not ,then just sand them flush.
-- Ken from Ontario, Canada
View TravisH's profile
568 posts in 1870 days
#8 posted 12-17-2014 05:25 PM
A jointer would not be one of my choices. I would be very worried of chip out even with a backer. Depending on how proud they were I would be more inclined to use block plane, file/rasp, or sander.
View newwoodbutcher's profile
732 posts in 2785 days
#9 posted 12-17-2014 06:53 PM
A hand plane is what I use
-- Ken
View pintodeluxe's profile
5595 posts in 2748 days
#10 posted 12-17-2014 07:08 PM
Any power tool besides a ROS will risk some tearout. A hand plane can cause tearout too (even a low angle block plane).
I trust sanding the most in these situations. If you don’t like that idea, a flush trimming router bit would work.
View gfadvm's profile
14940 posts in 2625 days
#11 posted 12-18-2014 01:02 AM
I use either my stationary belt sander or a flush trim router bit in the router table (a spiral cut bit will decrease tearout). The ROS seems to take forever to take these down flush.
View bobasaurus's profile
3396 posts in 3119 days
#12 posted 12-18-2014 01:04 AM
I like using my kugihiki flush-cut saw from lee valley for this task, it can cut things right up to another surface without damaging that surface. I then use a low-angle plane to clean up the joint, little to no sanding required.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View Logan Windram's profile
Logan Windram
344 posts in 2397 days
#13 posted 12-18-2014 01:10 AM
The jointer will blow out the fingers at the end of the cut, so no.
Block plane or even a razor sharp blade on 5, ideally a 62 low angle plane.
Sanding will leave uneven surface almost guaranteed that you will notice after finishing. I’d plane then sand for surface prep only.
#14 posted 12-18-2014 01:51 AM
Used the ros, it did take a while.
View KnickKnack's profile
1088 posts in 3501 days
#15 posted 12-18-2014 08:45 AM
I used to do this with a sander, but I found it hard to keep the surface perfectly flat.
Now I clamp a piece of sandpaper (or part of a roll) onto a flat surface, and, moving the box over the surface, sand it that way – if your sandpaper is tight, the box sides stay flat. It makes less noise, less dust, and I tell myself I’m doing some “hand-tool” work.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
