Worn out plastic gear on cheapo chain saw - replacement?
Forum topic by Thuzmund posted 12-17-2014 06:18 AM 2756 views 0 times favorited 8 replies Add to Favorites Watch
View Thuzmund's profile
Thuzmund
148 posts in 1501 days
12-17-2014 06:18 AM
Just curious if anyone has encountered a similar situation. Cheap tool and silly question, so don’t read on unless you’re as cheap an/or curious as I am.
My cheapo Harbor Freight electric chainsaw crapped out. When I took it apart, I found the motor shaft driving a sprocket, which links with a plastic gear of sorts. Of course, the plastic gear is stripped to all hell. The saw is about 4 months old—old enough that I can’t take it back but lots of life left in the bar, chain and motor. I would really like to just replace this part.
2 questions:
1) Has anyone replaced this part, or one like it before? What’s it called? Do you know of any chainsaw parts suppliers? I have the regular Ace, Lowes and so forth around me. I imagine this would be a mail order for me.
2) The bearing on the front is really friggin hard to get off, and I would need to do that to replace the worn gear. How the heck do I get it off?! I think I need a microscopic 3 jaw puller! :-D
I’ll try to keep this thread updated for future reference. in the meantime, feel free to chime in!
thanks
-- Here to learn
8 replies so far
View mahdee's profile
mahdee
3830 posts in 1640 days
#1 posted 12-17-2014 01:30 PM
Usually HF tools come with a manual that describe the parts. If you don’t have it, you can get in online and order the part from them. Be ready to wait several weeks and e-mails saying it had to be reordered. Just keep telling them to go ahead and re-order. Some parts will ship directly from China.
-- earthartandfoods.com
mahdee
#2 posted 12-17-2014 01:31 PM
I believe the part is called sprocket shaft.
Thuzmund
#3 posted 12-17-2014 03:47 PM
Thanks, it’s labeled as “gear” in the manual :-D
-- Here to learn
View Loren's profile
9765 posts in 3520 days
#4 posted 12-17-2014 05:02 PM
That’s cheap chain saws. It’s really a tool where
investing more is worth it. I have a Craftsman now
and it works well. I had a used, older one for awhile
when I lived in the Northeast. It was heavy and ugly
but it worked well and cost us only about $50.
View wseand's profile
wseand
2796 posts in 2914 days
#5 posted 12-17-2014 05:07 PM
Your a wood worker make one. :-)~ Other then that I have nothing useful. What’s new, right.
View oltexasboy1's profile
oltexasboy1
250 posts in 1576 days
#6 posted 12-17-2014 05:13 PM
What you need to pull that bearing is called a bearing splitter. You might be able to rent one from an auto parts store or a friend that is a mechanic. It works with a regular 2 jaw puller, otherwise you run the risk of ruining the bearing trying to get it off the shaft. I would offer to loan you mine but NY is in way far East Texas and the gas would be more than the tool.
-- "The pursuit of perfection often yields excellence"
Thuzmund
#7 posted 12-17-2014 05:20 PM
It looks like all the cheapo saws under 100 bucks (Remington, Poulan) use that plastic gear, from what I gather searching for parts.
Thanks for the tip on that tool name. I do think spending more is worth the investment, now that I use it so much for wood turning. Without this tool, I’m suddenly stopped in my tracks. I’ll be damned If I start splitting logs with a hand saw or 250 hammer blows!
Golly…but maybe someone will find this thread and avoid the low-end electric saws, unlike me!
-- Here to learn
wseand
#8 posted 12-17-2014 05:26 PM
You might look on CL there is good finds on there. Pick up a used one…
