'54 Craftsman table saw (restore proj)
Forum topic by Neodogg posted 1583 days ago 3945 views 0 times favorited 8 replies Add to Favorites Watch
View Neodogg's profile
Neodogg
94 posts in 1625 days
1583 days ago
Howdy, I was able to drag back my G-pa’s old Craftsman table a couple weeks ago. I was able to find the manual on OWWM.com and am guest-imating it to be around 1954. It is almost complete has the fence(removed for transporting), mitre gauge, and motor. I did a little test patch on the rust, does any one have any suggestions on restoring it? I was planning on taking the front plate off, sanding it all down and painting it. Also I was going to make some extension wings, couldn’t find the original one. It has the original motor, what things should I look for in that? Dad said it was rebuilt a couple years ago, I’m guessing new ball barrings? I greased up the underside and the blade moves smoothly up & down & all around. Going to have to make some blade inserts, can you use 1/4” hardboard or birch ply?
54 tablesaw
You can see a part of the ‘51 Walker-Turner drill press in the background.
Any help would be great.
Thanks
-- If you can't fix it with a hammer, you've got an electrical problem!
8 replies so far
View Woodchuck1957's profile
Woodchuck1957
944 posts in 1962 days
#1 posted 1583 days ago
That looks like a prodject that should keep you busy for a while. For rust, I’m a big fan of sand or bead blasting, it’s about the only way I know of to get rid of all of it. The last set of inserts I made from 3/8” masonite.
Craftsman on the lake
2028 posts in 1635 days
#2 posted 1583 days ago
sand blasting as Woodchuck said.. also near the end of the sanding process a grinder with a cup shaped wire brush helps polish things up.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://gagnerwebsite.com/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
View marcb's profile
marcb
762 posts in 1871 days
#3 posted 1583 days ago
I’ve heard great things about a product called Evaporust. Just paint it on and wait.
View brianinpa's profile
brianinpa
1809 posts in 1921 days
#4 posted 1583 days ago
What size motor: 3/4 or 1 hp? If you are going for disassembly, photo document everything before and after you are taking it apart: it will save you many headaches when you go to re-assemble it. Depending on how much it was used since the last rebuild, bearings are probably a definite. Several different options with respect to the rust, but I always use emry cloth and wet/dry sand paper with WD-40 – works good but requires a lot of work.
View Francisco Luna's profile
Francisco Luna
936 posts in 1591 days
#5 posted 1583 days ago
I personally prefer to leave old things with the old look. I would grab Butcher’s Wax and steel wool to clean all the visible rust.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View EEngineer's profile
EEngineer
778 posts in 1811 days
#6 posted 1583 days ago
For the base, I’d have to go with sand or bead blasting (beads will remove less metal). If you sand the base, definitely use the cup shaped wire brush mentioned earlier or it will rust right up again, paint or no paint. The handles will clean up fairly nicely with a little scouring powder unless they are heavily pitted. Go easy on the machine-turned aluminum front plate or you’ll smooth it all off – unless it is heavily pitted, you may not need any more than a good scrubbing with a rag and some gritless cleaner.
For the top, sanding or bead/sand blasting may remove the original machining marks. That is not necessary unless the top is heavily pitted, at which point you’ll probably want the top reground anyway. Mine had minor pitting and I wanted the rust out of those pits so I used phosphoric acid (naval jelly) and a general polish with green scratchy pads to make it look like new again.
A saw this age, bearings are probably required all around (arbor and motor), clean and lube the lift and tilt mechanisms. Table extensions, blade inserts and many other parts for these saws are available on e-bay all the time.
See owwm.com for info on these machines and techniques for restoring. Good luck and please post pictures during the restore process.
EEngineer
#7 posted 1582 days ago
Evaporust looks very interesting. The phosphoric acid I used created nasty fumes and a slight disposal problem. Of course, it is an acid, so normal cautions about eye irritation, etc. apply. If I understand the chemistry behind Evaporust correctly, this is not an issue with it.
Has anyone tried this yet? I’ve got a couple other cast-iron tables to clean this summer.
marcb
#8 posted 1582 days ago
EEngineer,
I’ve read about it on a different forum from people cleaning up old hand tools and such. It is a toss up between that and a brew made with Citric Acid that people are loving.
Electrolysis works and that’s what I use as I’m setup for it, but larger parts gets difficult without a large power supply and a swimming pool so I’m interested in these chemical methods.
