Floating Shelf
Forum topic by FloatingShelfChris posted 12-16-2014 04:23 PM 1056 views 0 times favorited 2 replies Add to Favorites Watch
View FloatingShelfChris's profile
FloatingShelfChris
1 post in 1257 days
12-16-2014 04:23 PM
Topic tags/keywords: box floating shelf shelf zclips
Hey Guys,
I’m looking for help on mounting a floating shelf.
The shelf has a closed back to it (basically making it a box) and I’m considering using Z-Clips to mount it flush with the wall?
Is this a good plan?
I was considering buying these
http://www.amazon.com/Rockler-2-Z-Clips-10-Pack/dp/B005UXIXWY/ref=pd_cp_hi_0
any thoughts?
2 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2368 days
#1 posted 12-16-2014 05:02 PM
I would skip purchasing the hardware, and just make a cleat on the back of the shelf. One side screws to the wall, one to the shelf, and the shelf just slips on.
http://niuartmuseum.blogspot.com/2010/09/french-cleats-vitrines.html
You could probably make a cleat in less time than it takes you to order those. Just take a board, angle the table saw blade, and rip it. That’ll get you both pieces.
Or, if this is a light-duty shelf, you could just make a recess in the back of the shelf, screw a strip to the wall, put the shelf over it (so the strip slides into the recess in the shelf), and drive a few screws up through the shelf, into the strip, from the bottom.
View lew's profile
lew
12060 posts in 3754 days
#2 posted 12-16-2014 05:46 PM
I’d leave the back open.
The attach what was to be the back, to the wall. Elongate the holes in the ””wall piece” slightly for leveling (at least I have to). Slip the opening of the box over the wall piece and attach the box to the wall piece with a flat head screw (or 2).
Unless the shelf is extremely heavy or protrudes quite a distance from the wall, this should take care of it.
