Forum topic by gadawg31 | posted 12-16-2014 02:16 PM | 996 views | 0 times favorited | 6 replies | ![]() |
Hello everyone, I have now started getting back into my wood hobby, after several years of being lazy. I have been reading a lot of the post regarding sanding sealers, grain fillers, stains, etc… and my primary concern goes back to stains and sealers. From what I have read and believe I understand this correctly, you cannot use a stain after using a sanding sealer. Is this correct or can you? I have been experimenting with several different projects, but wanted to get some opinions before I messed up too much stuff. What do you all think? Thanks. JD |
#1 posted 12-17-2014 01:47 AM |
JD, just to get the discussion started, you can seal the wood with a 1# cut of shellac, aka a spit coat, and apply a stain over it. This would be done to minimize blotching. You definitely need to test because the color imparted will not be as dark due to reduced colorant getting into the wood. Also, you might need to seal after the second coat to prevent muddiness from the second coat migrating into the third coat due to those two using the same solvent. Another option is to use a water borne product for the sanding sealer and then another product from the same manufacturer (to ensure compatibility). I do this with Target Coatings products routinely, but I don’t know about other manufacturers products. This works because the second coat “burns into” the first coat. Charles Neil is the resident expert and, perhaps, he will chime in here. -- Art |
#2 posted 12-22-2014 05:02 PM |
Thanks Art. I have been playing around, so I will give your process a shot. JD |
#3 posted 12-22-2014 05:37 PM |
I too use the thinned out coat of shellac for minimizing blotching, especially in Cherry. Sanding sealer generally has some additives in it that help when rubbing out a surface for final. These may impact your stain if applied over it. Generally, I would not use a stain over sanding sealer. -- Roger M, Aiken, SC |
#4 posted 12-22-2014 05:50 PM |
I don’t know about other sanding sealers, but Zinsser Seal Coat is just de-waxed shellac, so I use it just like Art’s 1# cut. I’ve stained over it many times with not issues—it really helps keep and even color on pine and other blotch-prone woods. (I really need to just start buying shellac flakes and mixing my own.) -- In matters of style, swim with the current; in matters of principle, stand like a rock. Thomas Jefferson |
#5 posted 12-22-2014 06:00 PM |
Thanks for all the info. I have never used shellac, so this is something that I need to try. I do have a quart of the Zinsser’s Seal coat, but was afraid to use it with the stain. I just finished a set of game boards for my sister and I wanted to try and stain them. I am kind of glad I didn’t now, they actually turned out pretty good. I was going for that heart pine look. Believe it or not, but these boards are actually pressure treated yellow pine that I reclaimed from my old deck. The boards are about two years old and I simply planed them down and re-used them. I have another set, that I will try the sealer and shellac techniques on. I tried to post a pic of the game board, hopefully it uploaded correctly. Thanks for all the suggestions. JD |
#6 posted 12-22-2014 10:44 PM |
Pat Keegan over at the YouTube Channel DIY Homebuilt has some real good pointers about finishes. |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6695 |
28056 |
CNC Woodworking
212 |
Hand Tools
5408 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
