Attaching a small moulding to the top of a bookshelf.
« back to Joinery forum
Forum topic by lateralus819 posted 12-16-2014 02:02 AM 910 views 0 times favorited 4 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1885 days
12-16-2014 02:02 AM
I’ve made a small book shelf. The top is 7.5” and the bottom about 9”. I want to attach a moulding to the top.
I was going to just put two dowels in but i got to thinking about wood movement and it causing issues. Would it be such an issue with only 7.5” of width?
Seen on the tops of the sides.
View Don W's profile
Don W
18710 posts in 2563 days
#1 posted 12-16-2014 01:58 PM
I’d say the movement will not be a concern, but I’d also say the dowel is overkill. (I’m assuming the top cap is the molding your referring to)
lateralus819
#2 posted 12-16-2014 11:34 PM
Yes it is Don. What would be “underkill”? How else would i attach it? Finish nails?
It would be end grain on the sides. That is why i figured dowels.
Don W
#3 posted 12-17-2014 12:42 PM
note, I see nothing wrong with overkill, so dowels will work, but you could also just dado and glue or finish nail.
The piece looks great!
View gmal's profile
gmal
19 posts in 1618 days
#4 posted 01-09-2015 03:25 AM
I built a set of built-n bookcases with plywood shelves, all covered with 3/4 inch molding. I pre-drill holes in the molding for small finish nails 16 or 18 size, and then nail it in. Bury head in wood, you wont see it.
