L-shaped bookcase: how to join at the 45
« back to Joinery forum
Forum topic by JoeZauner posted 12-15-2014 06:06 PM 1182 views 0 times favorited 4 replies Add to Favorites Watch
View JoeZauner's profile
JoeZauner
1 post in 1543 days
12-15-2014 06:06 PM
I’m new to wood working. Been at it on and off for a year with hand tools. I’m building an L-shaped bookcase and I’m looking for ideas as to how to join the top shelves where they meet at the 45-degree bend. Any input is appreciated.
-- I invented scary sharp.
View Woodknack's profile
Woodknack
11479 posts in 2345 days
#1 posted 12-15-2014 06:24 PM
Splines, biscuits, pocket screws
View mudflap4869's profile
mudflap4869
1662 posts in 1424 days
#2 posted 12-15-2014 06:27 PM
Ditto.
-- Still trying to master kindling making
117062 posts in 3542 days
#3 posted 12-15-2014 06:34 PM
If it’s made of solid wood you might want to use screws in oversize holes to allow for wood movement ,if its plywood then screws,pocket screws or even dados will do the trick depending on the design your using.
View gmal's profile
gmal
19 posts in 1587 days
#4 posted 01-09-2015 03:40 AM
How will the shelf inside the corner be supported? Whats the design? I built shelving units that met in the corner, but each wall is separate units.
