I'm working on a walnut slab table with a nakashima inspired base.
My plan to attach the top to the base is to route slots in the supports and drive wood screws into the top. I'm thinking three screws per support (one at center and one at each end). I have a few quesitons:
I'm not clear how these allow movement. I see that they pivot about the center screw, but then the screw in the table top would move radially, not laterally across the grain? It seems like this would still be restrictive? Thoughts?
Do you think these will work for my 42" wide walnut table top? Looking around on the internet, it sounds like I can expect somewhere between 1/2" - 1" of expansion.
Marshall
I use these Figure 8s all the time, they're one of a few ways to allow for wood movement. you drill a shallow hole in you cross members just the thickness of the fig8 at perhaps 4 locations for a 42" wide table,then screw the fig 8s down but you leave them loose enough to turn. you then screw them to the top of the table,they then swivel when the table top expands or contracts across the grain. You still will have one more issue to address re wood movement,it's your center cleat . You can attach it with screws but you need to elongate the holes in the cleat to allow the screws to move with wood movement.
waho609 must have been typing the same time I was,his photo shows all of the best techniques for attaching a table top,but for your application I feel the fig8s would still work best. For a table with an apron any of the connectors in the photo work great .
Thanks both of you for the advice! I'm going to use those "Z fasteners" for another table I'm working on that has an apron.
I made some wooden tongue and groove fasteners like the ones pictured for an old TV Stand project. I had a number of them split when I drove the screw. I dont know if i just didnt make them wide enough or what. I like the pre-made metal ones - less work for me
I think the approach you mentioned in your original post would work. You said this is made from 2 slabs of walnut, are they joined together, or separate? If they're joined into one slab, you could do a normal hole in the center of each cross piece, and elongated holes on each end of the supports. If they're separate, you may want to do two screws in the center of the support (one into each slab), and then elongated holes on each end.
I've only done this twice, both times were cleats for chest lids. Both times, I did elongated holes and used oval-head screws so that the underside of the screw head sat flush with the cleat.
- Marshall
If so, it sounds like you didn't pre-drill the hole in the fastener large enough. The screw threads don't need to engage in the small fastener, just the top it's attached to (it'll pull the fastener tight as you drive the screw in).
One more question - I found the figure 8 fasteners, but they are made for #6 screws. I can use a 1.5" screw - do you think a #6 is going to be strong enough to fasten the legs to the top if the table were to be picked up by the top?
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
