Grizzly G0690/ Shop Fox W1819 Blade Height Wheel Extremely Difficult to Turn
Forum topic by Hawk_Guy posted 12-14-2014 10:30 PM 2355 views 0 times favorited 19 replies Add to Favorites Watch
View Hawk_Guy's profile
Hawk_Guy
82 posts in 1648 days
12-14-2014 10:30 PM
Hell everyone, I recently purchased a Shop Fox table saw and was hoping to get some advice from others who may have experienced issues with their Grizzly version of my saw (G0690/G0691). The blade height adjustment wheel is extremely difficult to raise and efforftless to lower.
I have cleaned the gears and coated them with white lithium grease and have seen zero improvement. I’m really hoping there is a fix (within my means) because I have so much time invested in the assembly and allignment of the saw. I would be bummed if I had to repeat all that with a replacement machine.
There is nothing obviously binding but then again it’s difficult to see without removing the top and yes I loosened the knurled locking knob…
19 replies so far
View pjones46's profile
pjones46
1001 posts in 2643 days
#1 posted 12-17-2014 01:48 AM
Have to called Grizzly tech support? They may be able to point you in a direction.
-- Respectfully, Paul
View sawdustjunkie's profile
sawdustjunkie
383 posts in 1718 days
#2 posted 12-17-2014 01:56 AM
I have a 690 and have no trouble raising or lowering the blade. It is harder to raise the blade, because you are lifting the motor and 1/2 of the trunion, but it isn’t hard to raise and it isn’t binding.
I wouldn’t use alot of grease, just because it will attract all the sawdust to it.
-- Steve: Franklin, WI
Hawk_Guy
#3 posted 12-17-2014 02:36 AM
Hey Steve, thanks for commenting. I literally just uncrated and assembled this saw so it hasn’t seen a lick of saw dust. There is plenty of grease on the gears where they mesh. I get that the blade would be more difficult to raise but something is definitely wrong here.
I did contact shop fox and am awaiting action from them. It’s just really disappointing that I’ll likely have to swap this machine out with a new one. I just finished waxing the top!
There are metal shavings that are piling up beneeth the aft trunnion where the height adjustment shaft terminates.
View TheFridge's profile
TheFridge
9483 posts in 1487 days
#4 posted 12-17-2014 03:58 AM
That’s definitely not good. Worm gear not deburred maybe? Shot in the dark.
Hawk_Guy
#5 posted 12-17-2014 04:08 AM
The worm gear appears to be good to go. When lowering the blade the first 2-3 revolutions are just as difficult as when raising the blade then suddenly the binding noise stops and the wheel turns effortlessly. Its very difficult to determine the origin of the binding but I swear its the gear mesh. However, the metal dust is coming from the bushing at the aft trunnion.
View Paul's profile
Paul
721 posts in 1566 days
#6 posted 12-17-2014 04:25 AM
It could be my bad eyes on a 40” monitor but that looks like paint not metal to me.
paul
Hawk_Guy
#7 posted 12-17-2014 04:53 AM
Definitely metal, has a copper tone as well.
sawdustjunkie
#8 posted 12-17-2014 04:59 AM
It looks like the shaft bearing may be rubbing on the trunion. I think it is held in place by a allen screw. see if it is rubbing on the cast iron. it may be too tight.
Hawk_Guy
#9 posted 12-17-2014 02:57 PM
Just looked at the parts breakdown and it shows two copper washers installed on either side of the bushing in the trunnion. I’ll tinker with it tonight and see if something is installed wrong.
View RibsBrisket4me's profile
RibsBrisket4me
1554 posts in 2506 days
#10 posted 12-17-2014 06:08 PM
Boy, that’s frustrating isn’t it? Just get a new saw and have to tinker with it. I know “stuff happnes” but cripes!
Hope you get it all smoothed out and sorted soon!
Hawk_Guy
#11 posted 12-17-2014 06:38 PM
Update, I recieved a call from shop fox customer support and they explained that the nut at the end of the height adjustment shaft can be backed off and will allow more freedom between the gear mesh. Fingers crossed, I will try this first thing when I get home.
@RibsBrisket4me
The experience has been a little furstrating but probably because I don’t have a lot of patience. They did respond in good time and were very pleasant. I have an entirely seperate issue with the fence that has been documented in my review of the Shop Fox W1819 on Lumberjocks. There are some quality issues that really bug me and I feel like I got the runaround on the phone today regarding those issues. I will give all the details on that later tonight. Bottom line is the saw has the potential to be awesome but comes with minor issues. I personally don’t feel that after spending $1500 I should have to take things apart and reinstall them as they should have been in the factory. As for the fence it doesn’t sound like they will replace it so in short I may have to pick up some of my own metal stock and fix the defective parts on my own.
RibsBrisket4me
#12 posted 12-17-2014 06:47 PM
I totally understand your point of view.
The shaft sounds like an easy fix. The fence hopefully so.
I just hope that it does not ruin the enjoyment of your purchase.
You got a great saw.
View Rob's profile
Rob
316 posts in 2987 days
#13 posted 12-17-2014 10:23 PM
Just be aware that once you get things working right, you will experience the same difficulty with raising the blade once all the saw dust gets caked in there. I’ve yet to find a decent solution other than to use my air compressor to blow out as much as I can from time to time.
Hawk_Guy
#14 posted 12-17-2014 11:08 PM
I’ve read that some folks clean off all the grease and brush on some paste wax. The paste wax dries hard and shouldn’t attract as much saw dust. You could also try spray on Teflon.
Hawk_Guy
#15 posted 12-18-2014 12:02 AM
Update#2, loosened the suggested nut and no improvement at all. I backed the nut off gradually until the point of stupidity and it had zero effect the the hand wheel. I could still hear the gears binding…Wonderful. I guess I’ll remove the entire assembly and see where that goes.
