Help With Shellac
Forum topic by hokieman posted 12-14-2014 07:44 PM 1336 views 1 time favorited 26 replies Add to Favorites Watch
View hokieman's profile
hokieman
181 posts in 3656 days
12-14-2014 07:44 PM
I have never used shellac before. Always used lacquer and polyeurathane. I have always read that an advantage of shellac is you could spray a coat and it would dry very quickly (in 30-60 minutes) you could sand it down, spray again, etc. you could pretty much finish a small project in a day. So I tried it on a small project and I am finding it takes a long time to dry. I am spraying thin coats. Using a 2 pound cut. I didn’t mix flakes with alcohol. It’s Zinser. I live in Texas where it is in the high 60’s to low 70’s. This stuff doesn’t dry even over night. Still gummy to the touch. Any thoughts or advice?
26 replies so far
View Logan Windram's profile
Logan Windram
344 posts in 2364 days
#1 posted 12-14-2014 08:12 PM
How old is the can? If it’s too old, I believe it remains tacky, etc. since you have never used Shellac, I’d assume it’s new.
I have never used Shellac in any environment other that very, very arid. I can’t imagine humidity would prevent it from drying-
4868 posts in 2395 days
#2 posted 12-14-2014 08:28 PM
Yeah, it sounds to me like you have some really old stock. Freshly mixed flakes will only keep several months, Zinnser has some magic they mix into their products to make them last quite a bit longer (up to 3 years, I think). Even so, if the can has been stored improperly, or is way out of date…it won’t dry. Be aware, if you just bought that and the store doesn’t have a good inventory turn it may have aged sitting in the store. The cans are code dated, but I’m not sure the general public has the key to deciphering it.
hokieman
#3 posted 12-14-2014 08:46 PM
Just got it from a big box store. No date on it though.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2211 days
#4 posted 12-14-2014 08:58 PM
What they said about old stock. I’ve used plenty of seal coat that dries easily in 30 minutes. My shop is usually about 40% humidity and 70 degrees.
AlaskaGuy
#5 posted 12-14-2014 09:12 PM
- hokieman
Some where on that can will be a date code. I think with seal coat it’s the lot #.
Found this on a Google search:
I sent Zinsser/Rust-Oleum an e-mail asking about their shellac. This is their response…
The lot number that you have was manufactured May 17th, 2010.
S05179 reads as follows, S-Somerset NJ.
The first digit after the letter is the year of manufacture 0-2010.
The second digit is the month 5-May. (O-October, N-November, D-December).
The next 2 digits are the day of the month 17-17th day.
The final digit is for our records, the batch was made on the 9th run of the day.
Shellac has a 3 year shelf life.
We hope this is helpful. Please let us know if we can be of any further assistance.
Regards,
Eric
AlaskaGuy
#6 posted 12-14-2014 09:15 PM
Oh on another note. Seal coat cans have a habit of springing leaks in the bottom of the can. Re-package it or set the can in a try or something, it makes a real mess when the leak. DAMHIKT
#7 posted 12-15-2014 01:00 PM
That’s good info, I wasn’t sure they let that out. Thanks! To the OP: that’s a good point about the can leaking, there have been quite a few instances of this happening. I put mine in a plastic bag when it’s in storage.
View OSU55's profile
OSU55
1513 posts in 1891 days
#8 posted 12-15-2014 01:14 PM
Agree with all the others that the shellac is too old. To test shellac for curing – put a few drops on a piece of clean glass. If it doesn’t dry in 60 minutes or less, it’s too old. I dissolve flakes and date label the container, but sometimes it can sit for quite a while before I use it all. I use this test to know if I need to pitch it.
View Purrmaster's profile
Purrmaster
915 posts in 1995 days
#9 posted 12-15-2014 02:24 PM
I’ll add my agreement: Your shellac should absolutely be dry after waiting overnight. I’m assuming you are spraying the stuff straight from the can. Did you thin it first? What did you thin it with?
The Zinsser stuff is supposed to have something in it to increase the shelf life. But what you are describing does sound like old, worn out shellac (staying gummy). I’d contact Zinsser and see if they can confirm the date and maybe replace the can.
A test you can do is this: Take some shellac and drip some onto a piece of glass. Let it sit for a few minutes. Then tip the glass vertical. None or very little of the shellac should be running down the glass.
116900 posts in 3479 days
#10 posted 12-15-2014 03:50 PM
Your shellac may not be old ,but it may have been in a frozen environment. Given the temperature through out the US it’s possible this shellac was setting in a truck some where they had subzero temperatures. I’d return it and do a test on the new can’s contents before you go,usually in these cases the paint department will do it for you.
hokieman
#11 posted 12-17-2014 01:59 AM
Thanks for all the comments. I contacted Zinsser and the lot number says it was made in Feb of 2014, so it’s fresh. It isn’t temperture related as I live in south Texas where it’s been in the upper 60’s to lower 70’s. The Zinsser folks suggested that I have sprayed it on too thick. Sure doesn’t seem that I did. I like the results once it dries, though. Next time I’ll my own and see how,that goes.
#12 posted 12-17-2014 02:05 AM
Because you live in texas doesn’t mean that the product wasn’t shipped from a cold climate .
View waho6o9's profile
waho6o9
8098 posts in 2479 days
#13 posted 12-17-2014 03:09 AM
Maybe thin it out with something.
#14 posted 12-17-2014 03:16 AM
The only thing you thin shellac with is denatured alcohol .
waho6o9
#15 posted 12-17-2014 03:19 AM
Thank you Jim
