Best to apply Titebond glue to a large area?
« back to Joinery forum
Forum topic by Joel_B posted 12-14-2014 07:25 PM 3034 views 0 times favorited 34 replies Add to Favorites Watch
View Joel_B's profile
Joel_B
347 posts in 1502 days
12-14-2014 07:25 PM
I glued some 2×3s together lengthwise and had to apply a lot of glue so I used a foam brush.
Ended up with way too much squeeze out and the foam brush soaked up a lot glue.
Is there a better way to apply the glue? Would a small roller be good?
This time I am heating it in some hot water so I can get a thinner coat.
-- Joel, Encinitas, CA
34 replies so far
View NoThanks's profile
NoThanks
798 posts in 1650 days
#1 posted 12-14-2014 07:36 PM
I pour it on and used a notched trowel to spread it around. Start in the center with a little to see how it’s covering then add as needed to get it all the way to the edges.
-- Because I'm gone, that's why!
View jerryminer's profile
jerryminer
944 posts in 1562 days
#2 posted 12-14-2014 07:45 PM
I get good results with a small “disposable” paint roller. I pre-load the roller with glue so it doesn’t soak up any more. Afterward, I wash out the roller and use it again.
View Bogeyguy's profile
Bogeyguy
548 posts in 2189 days
#3 posted 12-14-2014 08:05 PM
Old paint brush, you can thin the glue some also with h2O.
-- Art, Pittsburgh.
View Logan Windram's profile
Logan Windram
347 posts in 2583 days
#4 posted 12-14-2014 08:09 PM
I use old credit cards. Easy to spread, and easy to skim some off if it’s too much
View crank49's profile
crank49
4032 posts in 3092 days
#5 posted 12-14-2014 08:12 PM
I use old credit cards for glue spreaders..
You can make your own notches with tin snips.
View Rob's profile
Rob
704 posts in 3192 days
#6 posted 12-14-2014 09:22 PM
I think Rockler sells a glue roller kit which has hard rollers instead of porous foam rollers. I would think any hard roller would work. I just use one of those silicone brushes, but I like the credit card and trowel ideas too.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
117203 posts in 3698 days
#7 posted 12-14-2014 09:30 PM
Joel
Pour some glue on the surface and then use a scrap piece of Formica or a bondo spreader to spread evenly over the surface.
View timbertailor's profile
timbertailor
1594 posts in 1545 days
#8 posted 12-15-2014 12:45 AM
Rockler sells these. Works great.
TheWoodenOyster
1317 posts in 2056 days
#9 posted 12-15-2014 12:56 AM
A flat scrap is what I use. Anything in the trash with a straight edge works.
-- The Wood Is Your Oyster
View paxorion's profile
paxorion
1107 posts in 2166 days
#10 posted 12-15-2014 01:22 AM
- timbertailor
That’s what I use. I also use thin strips of wood when the workpiece is wider.
-- paxorion
Joel_B
#11 posted 12-15-2014 06:23 AM
Tried the credit card. Worked pretty good and didn’t waste much glue.
Also but blue tape along the edges and hardly got any glue on the surface.
Only problem was I didn’t notice one piece was not aligned when I clamped it.
Now I get some practice with the hand plane.
Good thing its only a router stand and cheap DF.
View AlaskaGuy's profile
AlaskaGuy
4371 posts in 2430 days
#12 posted 12-15-2014 06:39 AM
These work well. Can be had in many sizes.
View macatlin1's profile
macatlin1
78 posts in 3064 days
#13 posted 12-15-2014 02:36 PM
I used a foam roller and carefully washed out the glue (lots of glue) then one day I forgot and left the foam roller out and the glue dried. I decided to try it anyway and found out the hardened foam acted like a hard rubber roller. Worked great! And I could easily control how much glue I applied.
The trick I found to making a round roller is to store the wet foam roller with the shaft vertical so the glue runs to the end and doesn’t make a lump or flat spot on one side.
The above desktop shows just how many pieces I had to glue together!
NoThanks
#14 posted 12-15-2014 02:45 PM
Glad the notched trowel worked out for you.
I usually make mine about 6” wide out of a scrap pc of laminate. I cut the notches on my bandsaw usually leaving about an 1/8 in between notches. Height of the notch and spacing of notches is experimental depending what your glueing and how much glue you want on it.
View Gene Howe's profile
Gene Howe
10840 posts in 3549 days
#15 posted 12-15-2014 03:08 PM
Borrow your wife’s pinking shears and cut those credit card edges. Just don’t tell her.
showing 1 through 15 of 34 replies
