How would you cut a handle into a cutting board.
Forum topic by JeremyR posted 12-12-2014 07:35 PM 4455 views 0 times favorited 7 replies Add to Favorites Watch
View JeremyR's profile
JeremyR
11 posts in 1362 days
12-12-2014 07:35 PM
I’ve built a few cutting boards and would like to create a recess on the underside for easy handling. Im just not sure how to do it and would appreciate any suggestions. Below is an image of the type of recess im trying to create.
7 replies so far
View jmartel's profile
jmartel
7687 posts in 2059 days
#1 posted 12-12-2014 07:58 PM
Router bit with a bearing on top.
View SuperCubber's profile
SuperCubber
1016 posts in 2193 days
#2 posted 12-12-2014 08:35 PM
I would use a flush trim bit and a template.
Joe
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View MrRon's profile
MrRon
4638 posts in 3152 days
#3 posted 12-12-2014 08:42 PM
I think I would route a handhold into a strip of wood and attach it to the cutting board as a breadboard end. It would be safer than cutting into the board itself.
View Minorhero's profile
Minorhero
373 posts in 2513 days
#4 posted 12-12-2014 08:49 PM
I have done this before with a router and a pattern bit and a quick mdf template. Whole process takes 10 minutes when starting from nothing. Definitely the easiest way.
View SASmith               's profile
SASmith
1850 posts in 2896 days
#5 posted 12-12-2014 09:33 PM
I have used a router and template before.
Below is a pic of one made on the table saw using a dado blade.
-- Scott Smith, Southern Illinois
View DIYaholic's profile
DIYaholic
19539 posts in 2583 days
#6 posted 12-12-2014 10:31 PM
Just a few weeks ago, being my first cutting board….
I used what I had on hand.
A cove bit with bearing in a hand held router.
With the board upside down….
Just made shallow passes, until I reached full depth.
Used a stop on each end/side, to control length of handle.
View Neptuno's profile
Neptuno
32 posts in 1226 days
#7 posted 12-13-2014 09:19 PM
I use a covebit on a router table with two stops and progressively cut the hand recess.
-- We must all cross the line.
