14" Bandsaw tuning help.
Forum topic by bdresch posted 12-12-2014 01:46 AM 1186 views 1 time favorited 14 replies Add to Favorites Watch
View bdresch's profile
bdresch
141 posts in 1573 days
12-12-2014 01:46 AM
I am tuning up my new to me craftsman 22424 14” bandsaw. I replaced all the bearings and replaced the bent up stock spring with a Carter products one. I am attempting to coplanner the wheels and found a problem. When I install my 1/2 blade and tension it, the bottom wheel is .18” back from the top. When I tension my 3/16” blade, the wheels are perfect. Should I leave it as is coplanner with my small blade or shim the bottom wheel out so its coplanner with the big blade? Does that much deflection when tensioning seen right? On the 1/2 blade I only have it tensioned until the gauge on the back reads about 3/8. With the 3/16” blade I have to crank it to the 1/4” setting to get it to feel like enough tension to keep the blade on. Any help appreciated.
14 replies so far
View Tedstor's profile
Tedstor
1643 posts in 2598 days
#1 posted 12-12-2014 01:56 AM
Let me ask you this? Does it cut well? If so, don’t worry about being ‘perfectly’ coplaner and finding perfect tensioning.
A bandsaw is a silly machine that will drive you crazy trying to get everything just right. Pretty close is usually more than good enough. Just get it tuned to the point that it cuts well, and forget about it.
I pay zero attention to the tension gauge on the saw. I wiggle the blade back and forth while I crank the tensioer until the tension feels “bout right”.
bdresch
#2 posted 12-12-2014 02:05 AM
When I tension the 1/2” blade, the guidepost isn’t parallel to the blade. That’s thr biggest issue. I thought I would check everything before progressing to that.
View ElChe's profile
ElChe
630 posts in 1302 days
#3 posted 12-12-2014 03:19 AM
I’d tune it to the blade you will use the most. The one that will stay on the bandsaw. Your general purpose blade. As to the guidepost, mine isn’t dead on but I set my guideblocks and thrust bearings at the height I’m usually cutting. I don’t resaw much so I set it to cut 1” thick material.
View jumbojack's profile
jumbojack
1674 posts in 2589 days
#4 posted 12-12-2014 04:00 AM
Before you do any tweaking PLEASE view this video;
http://m.youtube.com/watch?v=wGbZqWac0jU
View emart's profile
emart
445 posts in 2593 days
#5 posted 12-12-2014 04:18 AM
I have a much older saw and my lower wheel is a good 1/3 inch off from the upper wheel. It still cuts 6 inch thick chunks of hardwood fine. the main thing is to make sure the blade guides are usable and making sure it can tension properly.
-- tools are only as good as the hands that hold them https://www.custommade.com/by/emeraldcrafts/
View DrDirt's profile
DrDirt
4423 posts in 3708 days
#6 posted 12-12-2014 04:47 AM
The video by Jumbojack nailed it.
WATCH THE VIDEO…
Coplaner is a old time wives tail…..he explains why you do NOT want to make the wheels coplanar.
He explains Coplaner starting right at 5:59 of the video.
jumbojack
#7 posted 12-12-2014 02:57 PM
I struggled with my bandsaw when I first got it. The first thing I did was buy a QUALITY blade. Then set the saw up using the methods Alex explains in the video. It is now the friendliest tool in my shop. I use Woodslicers and swear my them, but other knowledgeable Jocks use other brands and they swear by them. Just get a good blade (not from Sears). My saw cuts like a dream. THERE IS NO DRIFT. Oh, my saw is from Harbor Freight.
bdresch
#8 posted 12-12-2014 03:11 PM
Ok, I will throw coplanner out the window. Next step now is replacing my tension rod and nut. After a few tension/detension cycles of the 1/2” last night it’s starting to to strip. Any recommendations on a new rod? The engineer in me likes Iturra’s Spinner 4 with the cast iron hand wheel, acme threads, and bronz nut, but the cheapskate in me likes the $15 Peachtree crank.
View Jim Finn's profile
Jim Finn
2647 posts in 2887 days
#9 posted 12-12-2014 08:45 PM
Yes, what Jumbojack said! Watch the video and learn a lot.
-- Website is https://craftingcouple.com/
emart
#10 posted 12-13-2014 10:34 AM
I use timber wolfe myself. just avoid the cheap blades you see at sears or any home improvement store. the money you save isnt worth the pain it will cause later.
one thing that is important however, is the stand your saw is on. I noticed with my saw that by throwing away the crappy stand it came with and replacing it with a nice solid steel one it had much less vibrations in it and therefore more accurate cuts. I worked at a place that had a ridgid brand bandsaw which worked ok but the stand was falling apart which caused a lot of trouble.
View distrbd's profile
distrbd
2252 posts in 2412 days
#11 posted 12-13-2014 02:56 PM
After a few tension/detension cycles of the 1/2” last night it s starting to to strip. Any recommendations on a new rod?
- bdresch
Build a speed crank with a threaded rod,a wooden handle could be made if you can’t buy one:
-- Ken from Ontario, Canada
View Neptuno's profile
Neptuno
32 posts in 1283 days
#12 posted 12-13-2014 05:04 PM
Here is my take on bandsaw tuning:
The blade should ride in the middle of the top tire. What happens in the bottom wheel is meaningless to the tuning.
Forget about the machine tensioning gauge, use the smallest tension the saw will cut straight.
Be sure that upper side guides leave only the teeth exposed, and check the side clearance between the blade and guide blocks or bearings is only a paper thickness. With the machine running, the back of the blade should touch the back bearing only when cutting.
Last but not least, the saw must be sharp. If you cut curves on plywood and MDF, the teeth will wear more to one side and you won’t be able to use that blade to cut straight on real wood. A condition called “Blade drift” will occur.
Blade drift, contrary to many textbooks advice, is NOT something to live with by compensations, like changing the angle of the fence, etc. It is the result of poor bandsaw tuning, and it is perfectly and easily corrected.
Pedro
-- We must all cross the line.
jumbojack
#13 posted 12-14-2014 10:51 PM
I
I ended up cutting the brace off at the middle handle. Works like a charm.
jumbojack
#14 posted 12-14-2014 11:01 PM
Oh AND I ground some faces on the rod.
For my woodslicer 12 complete turns tensions the blade perfectly. At the end on the day I back it off 12. Takes about 10 seconds.
