does any one have
Forum topic by daddywoofdawg posted 12-11-2014 04:45 PM 898 views 0 times favorited 3 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1813 days
12-11-2014 04:45 PM
does any one have know of a source or can make a tambour?need one to use for a xmas project and
i don’t have the tools to do it myself.
3 replies so far
View JADobson's profile
JADobson
1334 posts in 2349 days
#1 posted 12-11-2014 04:49 PM
Lee Valley carries them:
Here is a small size:
http://www.leevalley.com/en/hardware/page.aspx?p=40161&cat=3,43738
and a larger one:
http://www.leevalley.com/us/hardware/page.aspx?p=40016&cat=3,43738
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View hairy's profile
hairy
2783 posts in 3771 days
#2 posted 12-11-2014 07:57 PM
Rockler has tambour, and bits to roll your own.
http://www.rockler.com/search/go?w=tambour&asug=&sli_uuid=&sli_sid=
-- My reality check bounced...
View Dan Krager's profile
Dan Krager
4228 posts in 2473 days
#3 posted 12-15-2014 12:35 AM
DWD, what are your specifications?
I have the cutters to machine 5/8” linear solid stock that you thread onto wires to hold the slats together. Can be any length. Use 1/16” common cable available at most hardware stores for the “wire”. The profile allows for finished appearance on both sides, and can be used in a reversing “S” curve not usually done with canvas backed rolls. You would need to cut the tenons on the ends unless you can tell me the finished length of the slats with tenons, which are usually 3/8” long (and 3/8” thick) on each end. This method requires a “lock” strip about 1 1/2” to start the roll. The name implies one of its functions, holding a lock mechanism. The width is used to drill holes in the back which hold the cable crimps out of sight.
PM me if this has potential for you.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com Now there's a face that would stop a clock! And seriously mess with small watches.
