Suggestions for removable panel cabinet doors
« back to Joinery forum
Forum topic by Dyllan posted 12-11-2014 06:22 AM 1682 views 0 times favorited 9 replies Add to Favorites Watch
View Dyllan's profile
Dyllan
1 post in 1496 days
12-11-2014 06:22 AM
Topic tags/keywords: question
I’m very much of a novice, but I’m planning to build new cabinet doors for our kitchen, and could use some advice. I’m making them like in this video: https://www.youtube.com/watch?v=d-fCL-ZAVWs
Basically, a 1×2 frame with grooves inside it that a thin board slides into. I was going to join the sides of the frame with pocket holes using a Kreg jig.
However, I’d like to be able to remove the top of the door and change the panels so we can effectively redecorate our kitchen with just a panel swap (my daughter can paint some to show off her artwork, we can put some together seasonally, or whatever). My question is, how can I make the top 1×2 easily removable while still keeping it firmly in place? I’ve heard of threaded inserts, but I’m not sure if they can be installed into pocket holes, or if there’s some other method that would work better (perhaps an alternative to pocket holes)?
Thanks for any advice.
9 replies so far
runswithscissors
2916 posts in 2259 days
#1 posted 12-11-2014 08:07 AM
One way would be to have a groove in the top rail (I assume the tops would be above eye level?) that you could slide panels into. It would be tricky to accomplish, but I think it could be done by using loose tenons for the top rail. In fact, you wouldn’t need to make a slot at all—just glue front and back faces of the rail to the loose tenons to make a lamination. I guess you would have to remove the doors to change panels, as they would probably be too close to the ceiling.
And as you surmised, pocket screws wouldn’t work for this, at least for the top rail. I like mortise and tenon better anyhow.
View MT_Stringer's profile
MT_Stringer
3183 posts in 3465 days
#2 posted 12-11-2014 05:23 PM
My thinking is the panels would rattle every time the door is opened or shut. I wouldn’t attempt it.
View LeTurbo's profile
LeTurbo
234 posts in 1819 days
#3 posted 12-11-2014 06:10 PM
I’m doing something similar for an artist friend, but the panels will be canvasses, and the frame will be … well, the frame. In this case, they’ll mount in from behind, with simple twist tabs to hold them in place. Another thought though, is that magnets could do a good job here, even those basic ones that are used to hold cabinet doors shut.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2603 days
#4 posted 12-11-2014 06:55 PM
I also think it’s going to rattle, not something I would do, but doesn’t mean someone else shouldn’t. What if you made the frames such that they aren’t meant to be disassembled, but focus more on how to get the panel out without needing to tear the frame apart apart. A couple thoughts come to mind :
- Attach the panel to the frame with hinges on one side (on the inside of the cabinet), and a turnbutton or two on the other. That way, as your tastes change, open the panel, slide a new insert in, and close it back up. If you installed glass as well, so the insert got sandwiched when you closed to door, it would allow you to put in thinner stuff, like art, fabric, etc.
- Turnbuttons on all sides, much like a picture frame has on the back.
- Rout a recess in the back of the top rail, so you can side new inserts down into a groove cut on the stiles and bottom rail
Basically, my ideas all seem to go back to the idea of building the cabinet door more like a picture frame, and less like a cabinet door.
runswithscissors
#5 posted 12-11-2014 07:57 PM
I realize my original idea wouldn’t work very well, or rather, would be very hard to do. The joinery would be too complicated. Instead, you could use the little clips that are made for holding glass panes into a rabbet. I used them for glass panels in the cupboard doors in my kitchen.
It’s true they do rattle, but not all the time. Only when there are earthquakes, which I guess means they’d be problematic in southern California. Ours rattle, but we quickly learned not to hear them.
View Dan Krager's profile
Dan Krager
4223 posts in 2468 days
#6 posted 12-15-2014 12:51 PM
Why not make a rather common rabbet in the frame pieces with a special saw kerf dado to hold a rubber retaining tape that looks like quarter round when installed. This makes for a strong frame (however you decide to build it) and allows all sorts of different panels including stained glass or raised panels just by pulling the “tape” and then re-inserting it.
The rabbets can be cut with a common bearing bit after the door is assembled. The special dado for the tape can be cut with a 1/8” slot cutter. This arrangement takes full thickness frames.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com Now there's a face that would stop a clock! And seriously mess with small watches.
5229 posts in 2727 days
#7 posted 12-15-2014 01:02 PM
- runswithscissors
This is what I did with an entertainment center, I tightened mine down so they didn’t rattle; worked fine.
View NoThanks's profile
NoThanks
798 posts in 1762 days
#8 posted 12-15-2014 02:06 PM
Dovetail the top Rail
-- Because I'm gone, that's why!
117416 posts in 3811 days
#9 posted 12-15-2014 06:45 PM
I think the most traditional way is just to make it removable is as others have stated ,as if it were a piece of glass with wood stops or swivel hold down hardware.
