Super Dust Deputy , before and after
Forum topic by hairy posted 12-11-2014 12:10 AM 2456 views 1 time favorited 7 replies Add to Favorites Watch
View hairy's profile
hairy
2783 posts in 3772 days
12-11-2014 12:10 AM
Finally got this rigged up, along with cleaning up a long neglected area. I like it.
I couldn’t find a Black Friday sale, but I got free shipping instead. Works for me! THANKS, Oneida!
My DC got better just by getting rid of this, and going with 6” hose.
I bought the hose, clamps and 5” to 4” reducer along with the cyclone and the braces. Connecting that 6” hose to the top of the cyclone generated a lot of cursing until I got smart about it. I secured it to the ceiling with a bungee cord to support the weight so I could use both hands to wrestle the hose on. I lubed it with some dishwash detergent and after more cursing it was on. I left the bungee attached, that’s a heavy hose.
I also used bungees to support the cyclone when it’s time to empty the barrel. All I have to do is hook up the bungees that are hanging back there, undo the clamp on the barrel and slide it out.
I sandwiched the barrel lid between two pieces of BB plywood. This is what is inside the barrel.
I haven’t yet given it a good workout, but it seems to me so far that it was worth it. Thanks to all for the good advice!
-- My reality check bounced...
7 replies so far
View crank49's profile
crank49
4032 posts in 3210 days
#1 posted 12-11-2014 04:17 AM
You got something against rigid ductwork?
hairy
#2 posted 12-11-2014 02:57 PM
I have thought about it, never worked with it. I wanted to get it up and running right away, it was easy to order everything at once. I also want flexibility, I don’t want to unhook the plumbing to empty the barrel.
Rigid duct does have advantages. During my search for all of this I saw one dealer of DC ductwork claiming 1 foot of flex hose has the resistance of 4 feet of rigid duct. I can see where a smooth surface on the interior is better. Metal duct might weigh less than what I’m using.
Which duct would you recommend? Metal, PVC or something else?
View UpstateNYdude's profile
UpstateNYdude
918 posts in 2223 days
#3 posted 12-11-2014 04:17 PM
PVC sewer pipe, metal will be far more expensive for any gauge above 26.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View Roger's profile
Roger
20965 posts in 3044 days
#4 posted 12-16-2014 01:35 PM
You will luv that addition to your dust collection. Since I added mine, I’ve emptied the can 5 times, and there is only a tennis ball sized of dust in my bag. I have a HF 2hp collector.
View Seabiscuit15's profile
Seabiscuit15
8 posts in 1484 days
#5 posted 07-17-2015 07:07 PM
Are you able to comment on any suction loss by going through the Dust Deputy? Have you tested the difference between a hose run using 6” hose direct from tool-dust collector vs. from tool-cyclone-dust collector?
If so, can you express any large or small differences?
Seabiscuit15
#6 posted 07-17-2015 07:08 PM
hairy
#7 posted 07-18-2015 12:57 AM
There must be some loss, nothing’s free. It might be measurable but it’s not noticeable. I have only used what is shown in the pictures.
Don’t let the fear of suction loss keep you away from this. I think it’s worth the cost.
