Thermal Treatment of Wood
Forum topic by Redoak49 posted 12-10-2014 03:44 PM 859 views 0 times favorited 3 replies Add to Favorites Watch
View Redoak49's profile
Redoak49
3743 posts in 2228 days
12-10-2014 03:44 PM
I got a plan for a toy dump truck and it showed using thermally treated or heat treated wood. If done right, it can darken a wood anywhere from a light caramel to almost a dark brown.
Has anyone have any experience either heat treating wood or working with heat treated wood.
I read some articles about the commercial heat treatment and they use a couple of different furnaces including a vacuum furnace and others a combination of steam and heat. The toy dump truck website just said to use an oven a 400°F for 30-60 minutes.
I concerns about cutting this wood, glueing it and even finishing it as it will come out of the oven with zero moisture. I probably would have to let it re-adjust to some moisture level.
I am hoping that someone has some helpful ideas about this. Worst case is that I will need to make some pieces of a couple of kinds of wood and try the heat treatment with some variation in time. I do have some concerns about using my wife’s oven.
3 replies so far
View pjones46's profile
pjones46
1001 posts in 2882 days
#1 posted 12-17-2014 05:31 PM
Here is an article which may be of some help.
The treating process is done before you use the wood which changes the properties, some pros and some cons.
-- Respectfully, Paul
View NoThanks's profile
NoThanks
798 posts in 1768 days
#2 posted 12-17-2014 05:45 PM
I’ve used heat treated poplar, it turned brown and looked like a light walnut. (I have a pic if interested).
Never done it in the oven though.
-- Because I'm gone, that's why!
pjones46
#3 posted 12-17-2014 05:51 PM
Here is another Link for information.
