Roubo leg - sliding dovetail & tenon question
« back to Joinery forum
Forum topic by Bugnurd posted 12-10-2014 12:09 AM 2708 views 0 times favorited 4 replies Add to Favorites Watch
View Bugnurd's profile
Bugnurd
105 posts in 1797 days
12-10-2014 12:09 AM
I just noticed that in the plan I’m loosely following for a roubo bench, it calls for a small shoulder on the inside edge of the tenon. Is this shoulder absolutely necessary? Will leaving it out compromise the integrity or stability of the bench? I could glue a 1×6 to each leg for the shoulder, but I’d rather not if it doesn’t need it. I just don’t know enough about joinery to decide. What do you think? This is where I’m at now…
-- Marc -- Worcester, MA
View BubbaIBA's profile
BubbaIBA
387 posts in 2583 days
#1 posted 12-14-2014 01:34 PM
A couple of thoughts, one addressing your question, the other unsolicited advice.
The shoulder is where the M/T joint gets a good part of its strength. As you have a substantial shoulder between the tenons an additional small shoulder would not add a lot of strength but it would cover up a rough mortice.
My unsolicited advice deals with the through tenon, I know it was traditional in older French work benches but from a strength stand point there is nothing to gain over a housed tenon that has been either “pinned” or even better draw bored. Because wood moves and the through tenons are presenting end grain there can be significant differences in movement of your slab and the tenons requiring more maintenance to keep the top true. .Also when doing maintenance on your slab with through tenons you will always have four areas of end grain to deal with.
I’ve built a bunch of work benches all with housed and pinned M/T joints to attach the slab to the base and none have ever had any stability problem. BTW, because my bases are put together using draw bored M/T joints the only glue used is in the laminations. If you are building the bench to work on, not to meet some esthetic idea I would lose the through mortices and go with pinned housed M/T joints.
ken
View JADobson's profile
JADobson
1290 posts in 2317 days
#2 posted 12-14-2014 02:03 PM
Just remember that there is absolutely nothing wrong with meeting an “esthetic (sic) idea”. I hope every thing I build lives up to the aesthetic ideal I’ve set for it. Not trying to say that there is anything wrong with the advise Ken has given you but just remind you that form is just as important as function even in a work bench. So make it the way you want it to look. However, I think the issue of wood movement with through tenons is not that much greater than with housed M/T. My bench has housed M/T and I’ve noticed some movement. That is the nature of wood.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
Bugnurd
#3 posted 12-14-2014 03:30 PM
Thanks for the thoughtful replies and advice. I’m not worried about hiding anything, especially since it would be under the top on the inside edge. I’m using mostly free salvaged 2 by softwood from crates for this, not some expensive hardwood, so I’m not worried a whole lot about aesthetics. I’m going with the thru tenons. Almost every operation on this build is a first for me, so pretty much any route I choose will be a valuable learning experience. Here’s how the tenons turned out.
View ElChe's profile
ElChe
630 posts in 1542 days
#4 posted 12-14-2014 04:54 PM
That’s looking mighty fine! Update the progress.
