Southern Yellow Pine Furniture
Forum topic by ChipByrd posted 12-09-2014 02:44 PM 1369 views 0 times favorited 11 replies Add to Favorites Watch
View ChipByrd's profile
ChipByrd
146 posts in 2129 days
12-09-2014 02:44 PM
Hello,
I have a nice stockpile of 2×12 – #1 SYP. I purchased it and stickered it in my garage for a couple months before building my workbench and some other shop furniture/jigs. The problem is (a good one I suppose) that I still have several really nice boards. I was wondering about using it for small furniture projects: stools, end table, etc. If I mill it and make sure it is sufficiently dry, would it be ok? Or will there be too much movement?
Thanks,
Chip
11 replies so far
View Tedstor's profile
Tedstor
1678 posts in 2835 days
#1 posted 12-09-2014 02:48 PM
I made a 5 board bench from SYP. Its rock-solid and has held the primer/paint very well.
View Bill White's profile
Bill White
5128 posts in 4163 days
#2 posted 12-09-2014 03:40 PM
Have you tested moisture content?
Bill
-- bill@magraphics.us
ChipByrd
#3 posted 12-09-2014 03:57 PM
No, I haven’t. I don’t have a moisture meter, but I am hoping Santa will bring me one for Christmas. With my workbench, I simply let the wood set in my garage for a couple months. I had heard that would be sufficient. But I’m not really as confident when it comes to building a piece of furniture for inside. If Santa came early and I picked up a moisture meter, what level of moisture would I want the wood to attain?
Tedstor
#4 posted 12-09-2014 04:52 PM
Were the boards freshly cut when you got them? I assumed you bought them from a lumberyard and would have been mostly dry at the time of purchase.
View jdh122's profile
jdh122
1052 posts in 3020 days
#5 posted 12-09-2014 05:04 PM
Generally softwoods move less, rather than more, than hardwoods. Quartersawn eastern white pine is far more dimensionally stable than all of the regular North American hardwoods. SYP has expansion-contraction rates similar to those of many hardwoods. See the table at http://www.finewoodworking.com/item/108898/calculating-for-wood-movement
The issue with softwoods tends to be the way that they are milled and dried. Wood sawn for construction purposes often has the pith still in it and may crack, or it has been stored outside uncovered and may warp as it dries, or it was dried too quickly. But if you have nice boards that have acclimated there is absolutely no reason not to make first-class furniture out of it. If it’s been in your garage for months I would expect it to be dry enough, although you may want to bring it into your house for a couple weeks.
-- Jeremy, in the Acadian forests
ChipByrd
#6 posted 12-09-2014 05:28 PM
I did buy them at a lumber yard. Thanks for that reference from Fine Woodworkng. That and the advice are greatly appreciated.
View Sactomike's profile
Sactomike
19 posts in 1485 days
#7 posted 12-09-2014 06:15 PM
Southern yellow pine is one of my favorite woods, when I can get it here in California. A while back I salvaged some 6/4 stock which I made into a Medieval style stool, with the legs ( single boards) set in a shallow boxed rabbet and through mortice and tenoned to the top. It worked beautifully!
ChipByrd
#8 posted 12-09-2014 07:44 PM
You guys have definitely answered my question. Thanks. Sactomike, I would love to see a picture of that stool. It sounds awesome.
19448 posts in 2059 days
#9 posted 12-09-2014 08:04 PM
In my opinion SYP makes beautiful furniture. I built a 3’x6’ dining table and bench from reclaimed SYP and finished with oil based poly. SYP is about the hardest of the pines. I have some in my shop to build a new kitchen island cabinet.
http://lumberjocks.com/projects/83534
View WDHLT15's profile
WDHLT15
1792 posts in 2678 days
#10 posted 12-10-2014 02:28 AM
Bring it inside for a month and it will be fine.
View Aj2's profile
Aj2
1881 posts in 2000 days
#11 posted 12-11-2014 05:42 AM
Hopefully the wood has been Kd dried.Or you may get some pitch coming out thru the finish.That would be my only con.Aj
-- Aj
