Cut aluminum on TS?
Forum topic by adrianpglover posted 12-09-2014 12:21 AM 981 views 0 times favorited 7 replies Add to Favorites Watch
View adrianpglover's profile
adrianpglover
48 posts in 1427 days
12-09-2014 12:21 AM
Topic tags/keywords: question tablesaw miter saw
I know I haven’t been active here in a while. I’ve been more active over at popupportal.com with a whole new set of projects. One of those projects has be heading back over here for a quick question…
Any comments/concerns with cutting aluminum on a TS? I have a ACB1000T60-P blade made by Concord Blades which is supposed to be able to cut non-ferrous metal and plastic. In the past I used it to roughly cut some 1/2” plexi as a mattress stiffener. Now I come to a project that requires me to cut a lot of 1-1/2” angle aluminum and I was wondering about cutting it on the TS. Now that I think about it, it may make more since to cut it on the miter saw.
Questions, comments, concerns?
7 replies so far
MrUnix
6336 posts in 2103 days
#1 posted 12-09-2014 12:32 AM
Aluminum cuts pretty easy.. you will be fine either on the TS or miter saw as long as it’s not crazy thick stuff.
View greenacres2's profile
greenacres2
313 posts in 2072 days
#2 posted 12-09-2014 12:52 AM
My Kreg TS miter gauge fence cut very nicely with a Freud 40 tooth combo blade. Nice clean cut, about an inch high and an inch from the end. A constant visual reminder to check that sort of thing!! I’m sure the proper blade would hold up better, but the Freud suffered no ill effects from one incident.
earl
View BorkBob's profile
BorkBob
127 posts in 2596 days
#3 posted 12-09-2014 01:08 AM
I have a 7.25” miter saw dedicated to cutting 1” x 2” x.188” aluminum angle. I use a non ferrous blade. It is imperative to clamp or firmly hold the stock in place and cut slow and steady. Ii put some duct tape on the saw’s contact surfaces to help hold the stock. EYE and EAR PROTECTION and I wear a long sleeve shirt fully buttoned.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
View Nubsnstubs's profile
Nubsnstubs
1245 posts in 1634 days
#4 posted 12-09-2014 01:57 AM
you probably should put some kind of lubricant on the balde to keep the aluminum from loading up on your saw teeth. Tool supply houses have something like Stick wax?. It looks like a tube of grease. You just slowly put it into a running blade until you have all the teeth coated. Takes a second or so, but your cuts will be much better. After cutting all your metal, just clean off the saw and blade, and the wood will never know you just cut metal. ............ Jerry (in Tucson)
runswithscissors
2652 posts in 1929 days
#5 posted 12-09-2014 02:49 AM
Any carbide blade will work for AL, but if you are going to do a lot of it, a dedicated blade is better. The main difference (as far as I know) is that the teeth have a negative rake.
As mentioned above, skin and face protection are needed, as the chips of AL can really sting. I even wear gloves if working on the TS (as opposed to miter saw). A good lube for the blade is common old WD 40. I haven’t tried Stick Wax.
Another point: don’t wear fleece. The chips will stick in it like burrs, and you’ll have to pluck them out with needle nose pliers.
On a related note, I tried HF’s 7 1/4 inch metal cutting blade on 1 X 1.5 steel square tube, 1/8” wall. Used the RAS, but had to push as with a miter saw, not pull. When pulling, it wanted to feed too fast, and stalled the saw. Had to cut about 20 pieces. When I was done, I closely examined the teeth, and they appeared to be in perfect condition. No broken carbide or signs of dulling. Very impressive.
Of course I was wearing full body armor.
runswithscissors
#6 posted 12-10-2014 05:35 AM
Since no one has chimed in since yesterday I’ll add another point: check the blade frequently for chip buildup on the face of the carbide. You can knock these off with a pocket knife. If you don’t, the cutting will degrade and there can be quite a bit of heat buildup, which exacerbates the problem.
View Nighthawk's profile
Nighthawk
554 posts in 2260 days
#7 posted 12-10-2014 05:45 AM
I happily put aluminum through my bandsaw…
-- Rome wasn't built in a day... but I wasn't on that job? ... http://www.wackywoodworks.co.nz
