ProCom Vent-Free Dual Fuel Infrared Radiant Wall Heater Safe For Dusty Environment?
Forum topic by Paul Bucalo posted 12-08-2014 01:12 PM 1299 views 0 times favorited 5 replies Add to Favorites Watch
View Paul Bucalo's profile
Paul Bucalo
638 posts in 1265 days
12-08-2014 01:12 PM
Topic tags/keywords: question
I found this discussed in a YT video by a woodworking peer who recently installed this in his workshop. The cost is very reasonable and since I have a natural gas furnace, and an unused connection in the dungeon, this seems like a good choice for me. What I am concerned about is combustion from wood dust in the air, plus the fact that I would have to locate this close enough to the floor to be hit with concrete and saw dust from moving around down the there. Is this a safe choice in a dusty environment?
-- -- Paul @ PMB Creative Works
5 replies so far
Paul Bucalo
#1 posted 12-08-2014 02:57 PM
I just got off the phone with one of my clients that sells and installs heating systems. They told me one of the by-products of ventless gas heating is moisture. Enough so that some of their clients have mentioned problems with tools rusting. Hmm.. So much for that idea. >_>
View Gene Howe's profile
Gene Howe
10126 posts in 3334 days
#2 posted 12-08-2014 03:37 PM
Paul,
I’ve used the one you pictured for 7 years in my shop. No problems with dust or rust.
I’ve heard the stories about excess moisture but have not experienced it at all.
Mine runs 24/7 during the winter to keep our well pump plumbing warm.
There is always a small window slightly open, which MAY alleviate any moisture problem.
I’m in Northern AZ, but my BIL in IL also runs one in his shop and has no problems either.
Paul Bucalo
#3 posted 12-08-2014 04:09 PM
Paul,
I ve used the one you pictured for 7 years in my shop. No problems with dust or rust.
I ve heard the stories about excess moisture but have not experienced it at all.
I m in Northern AZ, but my BIL in IL also runs one in his shop and has no problems either.
- Gene Howe
Thanks for your experience, Gene. When you get a chance, take a look at my blog for pics on what my dungeon looks like. It’s a 100+ year old railroad boom house, poorly built with field stone walls and some bare earth in the old coal bin area. In the heat of the summer it’s a cool 62 F and very damp. Throughout the winter it’s drier, but the temperature doesn’t get above 50 F. Water seepage from outdoors still occurs even below freezing. To open a window, even a crack would, defeat the effort I am putting into sealing air leaks and insulation between the house and stone.
When I talked with my client, I found a better choice to be a vented unit, which drew outside air for combustion through the same pipe it vented exhaust out. The cost was too high for me. Nope. Will have to try something else. :/
Gene Howe
#4 posted 12-10-2014 01:33 PM
In that environment, your choice to not use the ProComm unit seems quite wise.
I failed to mention that a slightly open window is mandatory when using a non vented heater due to possible CO build up.
Would “base board” heaters, mounted above any possible moisture contamination (horrors) work for you? Maybe a ceiling mounted electric unit? Something like this one?
Paul Bucalo
#5 posted 12-10-2014 04:37 PM
I was already aware of the need for ventilation, so you didn’t fail to mention what I needed to know. This was a concern of mine when I was first looking at the unit.
- Gene Howe
Gene, I know I have options. Whether they are affordable for me is the qualifier. Electricity is very expensive in our community. Also, my ceilings are so low that a ceiling mounted heater of the smallest size would blow into my face and I would bump my head into it. I think this winter I will have to stick with what I have and see how far I can go with it. I bought some tubes of construction adhesive (good to 0 F) and Titebond III wood glue that can handle down to 45 F. We’ll see how they work.
