Advice on a portable miter stand for the Hitachi 12" slider?
Forum topic by Razorburne posted 12-07-2014 03:09 AM 1746 views 0 times favorited 13 replies Add to Favorites Watch
View Razorburne's profile
Razorburne
41 posts in 1387 days
12-07-2014 03:09 AM
Hi there everyone,
I am hoping to purchase a Hitachi C12RSH 12” sliding compound miter saw. Most of my work gets done outside as the garage I currently work out of has no electricity. I know this saw is considered heavy and is best left in the shop, but I figure I can get a portable miter stand and simply wheel the saw out and to where I can hook it up to electricity (extension cords from house to garage are not an option – too far and think I would lose too much power).
Aside from its weight, I am aware from reading online that the Hitachi has an awkward base profile and on one side the mounting holes are not parallel. I can only imagine this might impact how it would attach to a portable stand.
I hear good things about the Rigid MSUV but not sure if this will work. Any advice?
13 replies so far
View wseand's profile
wseand
2796 posts in 3010 days
#1 posted 12-07-2014 03:27 AM
I’ve. Been using the Rigid for a few years now and its a great stand. The only problem is the extennsion aren’t that well designed and have to fuss with them a bit to get them in the right position. Otherwise, a great stand. Sturdy, folds up well, rolls great, and holds the saw tight.
Rigid review.
Razorburne
#2 posted 12-07-2014 03:51 AM
@ wseand,
what miter saw are you using with the Rigid stand?
View Paul's profile
Paul
721 posts in 1533 days
#3 posted 12-07-2014 04:00 AM
If your using it home only almost any of the 4 point miter stands will work. I use a cheap ryobi stand with my 12” hitachi slider on the job site when I’m on a second or third floor working. I chose the ryobi for the job site because lifting 30 lbs up 3 flights of stairs is alot nicer than lifting any of the rolling devices which are much more robust, heavy, and clumsy.
For your home, garage, or shop use pick any of them that seem to have the features you want. Your not moving it more than 50 feet at a time anyway.
Paul
wseand
#4 posted 12-07-2014 06:01 AM
I have a 12 inch DeWalt. DW718 I think number, DBevel slider jobbie.
View pauljuilleret's profile
pauljuilleret
101 posts in 1621 days
#5 posted 12-07-2014 09:59 AM
I have a Bosch gravity stand under my slider and love it it’s a bit pricy but well worth the cost in my opinion. around $300.00 as I recall but you can go most anyplace with it and it sets up with a snap. at least take a kook at it if nothing else when I got mine a few years back Bosch had a deal on where you but the 12” compound slider and they tossed in the stand it was a deal I couldn’t pass up and Lowes gave me an additional 10% off being a vet to boot. I think Home Depot now sell this stand instead of Lowes.
View dhazelton's profile
dhazelton
2756 posts in 2265 days
#6 posted 12-07-2014 01:07 PM
The problem with all the commercial stands that are collapsible is that you end up with a ton of wasted space. If you aren’t moving farther than out the door I would build a rolling cabinet with folding wings like Norm Abrams would make. Then all the space below the saw can be utilized.
wseand
#7 posted 12-08-2014 01:45 AM
I do like the idea of a rolling cart but I used the stand on job sites as well and it was nice to have.
Razorburne
#8 posted 12-11-2014 03:57 AM
what to do you guys think about using a piece of 3/4” plywood to create a sort of adaptor plate? A square piece of plywood that can be afixed to the stand, and attaching the miter saw to the plywood via screws/bolts/etc.?
seems like it should work, right?
View MikeJT's profile
MikeJT
3 posts in 54 days
#9 posted 03-31-2018 04:59 AM
- Razorburne
Yes it works except now the wings on the stand can’t be adjusted high enough to compensate for the plywood thickness. So your not getting the full benefit of the portable stand. But you can make one out of metal like this.
MikeJT
3 posts in 54 days
#10 posted 03-31-2018 04:59 AM
MikeJT
3 posts in 54 days
#11 posted 03-31-2018 05:00 AM
View tt1106's profile
tt1106
129 posts in 3037 days
#12 posted 03-31-2018 01:07 PM
Have that same saw mounted on a Harbor Freight Stand. It works great. If I had it to do over again, I probably would have bought a smaller saw. This thing is a beast! Great saw though, just big. I attached the saw to a base of 3/4 plywood and then mounted it to the stand. Works great.
-- -Todd
View Roy Turbett's profile
Roy Turbett
163 posts in 3548 days
#13 posted 03-31-2018 03:49 PM
I’ve had a 10” Bosch SCMS mounted on the Ridgid AC9944 stand for over 10 years and its fantastic. Its not the same as the Rigid MSUV you’re looking at and the older stand may be better than the new version. I mounted the saw and a pencil sharpener to a piece of 3/4” plywood that is mounted to the brackets. Its also very easy to remove the saw from the stand if you want to use it on a bench. One of its best features is its highly portable and the wheels are large enough to move the saw over uneven terrain. Another nice feature is that the front of the saw has skids that make it easy to load and unload into a truck. And it folds up and stores in a corner.
