Zinsser Bullseye Shelac
Forum topic by ric53 posted 12-06-2014 02:40 PM 2186 views 1 time favorited 22 replies Add to Favorites Watch
View ric53's profile
ric53
194 posts in 1759 days
12-06-2014 02:40 PM
Has any body out there had any experience with thinning Bullseye Shelac? I know it says on the can not to thin it but I would like to wipe it on if possible. If I can’t thin it what kind of wiping finish can I put on over it?
-- Ric, Mazomanie
22 replies so far
View endgrainy's profile
endgrainy
251 posts in 2128 days
#1 posted 12-06-2014 02:44 PM
You can definitely thin it with denatured alcohol. I usually thin it with a 50/50 mixture which results in (I believe) a “1lb cut.” The common advice is to use the dewaxed shellac (Zinsser Seal Coat) when using a different top coat (ie poly.)
-- Follow me on Instagram @endgrainy
View BigRedKnothead's profile
BigRedKnothead
8542 posts in 2222 days
#2 posted 12-06-2014 02:45 PM
Hmmm, I didn’t know it said that on the can, but you can certainly thin it with DNA. I do it all the time. Regular bullseye shellac has wax in it and shouldn’t really be top-coated with anything other than additional shellac. The wax may make topcoats peel.
However, zinsser also makes a product called “Sealcoat” which is just dewaxed shellac (which you can also thin). You can topcoat that with anything. It is ideal for sealing stains and dyes before topcoats.
-- "At the end of the day, try and make it beautiful....because the world is full of ugly." Konrad Sauer
5240 posts in 2733 days
#3 posted 12-06-2014 03:10 PM
It can be cut with no problems…not certain why they would say that unless you have one of their new “synthetic shellacs”. I have no idea what those things are, but they are being introduced.
View distrbd's profile
distrbd
2252 posts in 2686 days
#4 posted 12-06-2014 03:13 PM
Shellac can also be thinned with 99% Isopropyl alcohol.
-- Ken from Ontario, Canada
View Picklehead's profile
Picklehead
1053 posts in 2169 days
#5 posted 12-06-2014 03:55 PM
I think they’re required to say not to thin it because it’s low voc compliant and the goverment won’t allow THEM to allow YOU to add voc’s to it because, well, it makes the baby seals sad.
-- Quote from ebay tool listing: " Has nicks and dings wear and tear dust and dirt rust and pitting but in good working condition"
View OSU55's profile
OSU55
2033 posts in 2229 days
#6 posted 12-08-2014 10:43 PM
Shellac can be thinned with DNA or isopropyl alcohol, the 99.9% stuff should be used – don’t want the water. The isopropyl is good when brushing because it evaporates slower and gives more open time. Bulls eye shellac is a 3# cut, and SealCoat is 2# cut. I like to brush a 1-1/2# cut. A 1# cut means 16 oz or 1 lb weight of shellac dissolved in 128 oz or 1 gallon liquid. Golden tacklon brushes are by far the best for shellac.
Shellac sets very quickly and is typically not wiped on. The technique of French polishing is used to apply with a rag. It’s a slow tedious process. Brushing or spraying (especially large surfaces) is recommended. Jeff Jewitt at Homestead Finishing has some very good info on shellac at his website.
View buck_cpa's profile
buck_cpa
150 posts in 2127 days
#7 posted 12-08-2014 11:36 PM
I thin it with denatured alcohol 50/50 and wipe it on with a lint-free rag. I’ve had good experience. I’ve also used 0000 steel wool and “massaged” it into the grain – then wipe the excess with a clean rag – not sure if this is a prescribed method but it works well for me. If you’re new to shellac, I’d suggest thinning it more than 50/50… there is no harm it just takes longer get a good build up.
View Tim's profile
Tim
3812 posts in 2201 days
#8 posted 12-09-2014 12:55 AM
Apparently most DNA you can get isn’t very good quality and higher quality DNA makes a difference in the finish.
http://www.shellac.net/alcohol.html
Credit to bhog the lac guru.
View Woodknack's profile (online now)
Woodknack
12466 posts in 2620 days
#9 posted 12-09-2014 05:43 AM
I believe you will get frustrated trying to wipe shellac, just thin and brush. And I would not apply a wiping finish of any sort over it, actually I wouldn’t apply any finish over it. Either just use the shellac or use whatever else, unless you believe there some contamination in the wood that you need to seal.
OSU55
#10 posted 12-09-2014 04:02 PM
As for the quality of DNA, I’ve compared the so called high quality stuff and the cheap box store stuff and found absolutely no difference in the dissolving of flakes, application of the finish, cure time, or quality of the cured finish. The box store DNA will contain much more methyl alcohol, 40-75%, whereas Behlen and some of the others contain 90% or more ethyl alcohol. A proper respirator should be used when spraying, and brushing for lengthy periods, regardless which you choose to use.
View gfadvm's profile
gfadvm
14940 posts in 2930 days
#11 posted 12-12-2014 01:24 AM
Wipe/rub on is my favorite technique with shellac. I thin with DNA in 1:1 ratio.
View RogerM's profile
RogerM
799 posts in 2639 days
#12 posted 12-12-2014 03:17 PM
I always thin mine at least 50%
-- Roger M, Aiken, SC
View Magnum's profile
Magnum
10934 posts in 3272 days
#13 posted 12-13-2014 05:39 AM
When I used a lot of Shellac, I used Methyl Hydrate (as below) at 50/50 for thinning.
It also helps it dry a lot faster. I would only Brush it on. Nothing on top of that except more Shellac if desired.
I also used as a “Quick Dry Sealer” on other woods if they were to have a Painted Finish.
Note the other uses in the Ad. It’s also what they sell as Gas Line Anti Freeze for your car, only a lot cheaper this way. ...LOL..
This stuff is Highly Flammable, burns with a HOT Blue Flame that you can barely see. So … Be Careful Using It and in a well ventilated area.
Good Luck: Rick
-- Made In Ontario, CANADA
Woodknack
#14 posted 12-14-2014 05:06 AM
Shellac already dries fast, any faster and your brush will be stuck to the finish.
Magnum
#15 posted 12-14-2014 06:50 AM
- Rick M.
Not on it’s own it doesn’t. It also depends on what type of Shellac I’ve been using what I explained above, for a long time. I know what I’m talking about. You?
”any faster and your brush will be stuck to the finish.” HA! HA! HA! That was very Funny.
