Shoda Shaper-Spindle Moulder
Forum topic by unbob posted 12-06-2014 07:52 AM 2400 views 0 times favorited 9 replies Add to Favorites Watch
View unbob's profile
unbob
801 posts in 1806 days
12-06-2014 07:52 AM
I found this on CL for $700 with some cutters. It is a somewhat unusual woodworking machine from Japan, I think from the 1960s. Very heavy machine at 1800lbs, but has fine adjustments.
Any others out there?
9 replies so far
View MrRon's profile
MrRon
4628 posts in 3147 days
#1 posted 12-06-2014 07:45 PM
It definitely looks high quality. If you have a need for such a machine, I would buy it.
unbob
#2 posted 12-06-2014 08:12 PM
More or less excessive compulsive disorder from trying to get near perfect lock miter joints, I am where I want to be there-rapid set up, with ease of adjustment for varied thicknesses.
I use the router table a lot, I needed to run bigger cutters for some glue joints and not cook the router, also get better fits and finish on thicker pieces.
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3488 days
#3 posted 12-06-2014 10:03 PM
Really impressive and not expensive for what you bought.Have fun safely.Alistair
unbob
#4 posted 12-07-2014 07:03 AM
Prices on machines anymore is from free “please haul it away” to stupid high. The CL can be the great equalizer to having to buy a machine from a dealer. A lot of machines like this go to scrap now days.
I am used to moving heavy machines, I dismantled this one and re-assembled it in my basement workshop. That would be hard for someone doing something crazy like that for the first time. So, the heavier shapers go cheap.
unbob
#5 posted 06-30-2015 08:54 PM
I read about a machine type user that rigged the same “set up here” to rip saw strips of ebony and other hard woods from as thin to 1/16” at around 1/2” deep. I found this works well to a pretty high accuracy, and getting a good cut finish-no splitting.
Pretty much the wood is trapped in the slot in the sliding fixture, and run across the 5 1/2” Freud hand saw blade- arbor hole enlarged to fit shaper spindle. And run at 8000 rpms.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1239 posts in 1616 days
#6 posted 06-30-2015 09:34 PM
Looks like a top quality machine. Have newer seen one wiht that type of spindle support before.
Great buy!
-- "Do or Do not. There is no try." - Yoda
unbob
#7 posted 07-01-2015 05:53 AM
Yes, this is an odd machine, “Boeing surplus”.
The spindle is none changeable- 1 1/4”, the overhead support needs to be used full time due to spindle length. It can hold a cutter 7 1/2” above the table, or one that tall. All class 7 bearings in the spindle system, with circulating oil.
kaerlighedsbamsen
#8 posted 07-01-2015 06:52 AM
Looks like it could be made for operations like this one: http://www.owwm.net/?p=1055
View SirIrb's profile
SirIrb
1239 posts in 1134 days
#9 posted 07-01-2015 10:58 AM
Buy it.
There is nothing more to say about this. Case closed.
You arent at Boeing yet, Sillypants?
