Federal Eagle Marquetry - Feathers
« back to Scrollsawing forum
Forum topic by jonsprague0000 posted 12-06-2014 04:14 AM 1366 views 0 times favorited 6 replies Add to Favorites Watch
View jonsprague0000's profile
jonsprague0000
104 posts in 1588 days
12-06-2014 04:14 AM
Topic tags/keywords: federal style marquetry inlay eagle
I’m attempting to do a federal eagle in marquetry and am not sure how to handle the feathers on the wings. The feathers are too small for me to cut, but the example I’m trying to reproduce has small black lines that make up the feather. Can someone please suggest how I can make the small black lines that make up the feather?
View shipwright's profile
shipwright
7980 posts in 2797 days
#1 posted 12-06-2014 04:22 AM
They’re called engraving lines. They are just saw cuts. When you assemble the marquetry and apply a dark mastic filler the filler will highlight the lines. The tops of the wings are sand shaded as well.
Good luck on the project.
View Yonak's profile
Yonak
986 posts in 1520 days
#2 posted 12-06-2014 02:02 PM
For the shading, there is a technique called sand shading. An internet search should supply needed information about it.
jonsprague0000
#3 posted 12-07-2014 02:08 AM
Thanks everyone. Shipwright, what type of mastic filler would you recommend? Would a mastic filler be dark wax?
shipwright
#4 posted 12-07-2014 02:20 AM
I use fine sawdust and hot hide glue. You can color the dust with tempera paint powder. You can use PVA glue but you will have more problems with finishing. I also doesn’t dry hard as HHG does. Apply the mastic from the back (glue side) before applying the marquetry to the piece.
jonsprague0000
#5 posted 02-23-2015 01:00 AM
Shipwright, I did it! Check out the final product.
http://lumberjocks.com/projects/131193
shipwright
#6 posted 02-23-2015 01:50 AM
Looks like a winner.
