I need to find a home for my lathe in my shop
« back to Woodturning forum
Forum topic by Rick Bailey posted 12-06-2014 01:54 AM 1302 views 0 times favorited 18 replies Add to Favorites Watch
View Rick Bailey's profile
Rick Bailey
247 posts in 1327 days
12-06-2014 01:54 AM
Dose it work out better to have the lathe against a wall or out in the middle of the room?
I don’t have a lot of room to work with because of all the other big tools, with that said I’ll need to bolt the thing to the floor sooner or later. Just wondering what you guys did, pics would help me a lot.
Thanks,
Rick
-- I'll bulid your dream,you tear it down.
18 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2641 days
#1 posted 12-06-2014 02:16 AM
I have always used the lathe near a wall. Might be me but it seems natural that way. I have a shows with 2 overhead doors in the same wall. The lathe goes between those doors perfectly. I also made it easy to mount dust collection behind the lathe.
View Minorhero's profile
Minorhero
373 posts in 2570 days
#2 posted 12-06-2014 02:30 AM
Definitely against a wall. The lathe will never need to be in the middle of a room whereas large pieces of stock might need that room. At the very least you may need that space for assembly at some point.
Leave enough room between the lathe and the wall to get behind it if you need to clean back there etc.
View emart's profile
emart
445 posts in 2593 days
#3 posted 12-06-2014 02:37 AM
you could also put its stand on locking wheels so you can move it around as needed. I keep mine against a wall but i also do not have much choice in the matter. All my tools are against the walls of my gambrel shed
-- tools are only as good as the hands that hold them https://www.custommade.com/by/emeraldcrafts/
Rick Bailey
#4 posted 12-06-2014 03:01 AM
- Grandpa
Grandpa,
Thank you for your input I always like reading your post, but sir I did not understand “I have a shows with 2 overhead doors in the same wall. The lathe goes between those doors perfectly. I also made it easy to mount dust collection ”
Minorhero,
Great minds think alike.
emart,
This guy is too big to put on wheels, I feel I need to bolt it to the floor for safety.
Keep it coming guys, I’m realty enjoying the input.
Best,
Rick
View Mark's profile
Mark
901 posts in 1940 days
#5 posted 12-06-2014 04:15 AM
Hey Rick. You never said how dig your tool is. :) If it’s a bigun’ I can’t help ya. I have a midi lathe on a rolling stand I built with 2×4’s. I’m stuck in a single car garage, but it works great.
-- Mark
View bondogaposis's profile
bondogaposis
4683 posts in 2317 days
#6 posted 12-06-2014 04:42 AM
I use mine against the outfeed table of my table saw. I set up so the ways are at the same level as the outfeed table.
-- Bondo Gaposis
View Florida_Jim's profile
Florida_Jim
83 posts in 2843 days
#7 posted 12-06-2014 01:54 PM
In my spatailly challenged shop, I have mine on a mobile base.
I can move it to where it’s most convenient.
View mrg's profile
mrg
818 posts in 2965 days
#8 posted 12-06-2014 02:37 PM
I have a Nova DVR mounted on a stand I made that I am able to roll around since I don’t have a wall to keep it against. I find that it is nice to be able to walk around the lathe while adjusting blanks and makes it easier for cleanup. .
-- mrg
View hairy's profile (online now)
hairy
2655 posts in 3498 days
#9 posted 12-06-2014 02:51 PM
Mine is out in the open. I turn from both sides.
http://lumberjocks.com/hairy/workshop
-- My reality check bounced...
View LeeMills's profile
LeeMills
522 posts in 1267 days
#10 posted 12-06-2014 03:16 PM
Mine is against the wall with a cabinet behind it (on the wall) to hold almost every turning item/tool. No I don’t have to reach across spinning wood to get an item. I use a simple $10 extension for the air gun to blow the shaving out from behind it.
Others mentioned the convenience of your dust collector to the area and you will probably also need a movable cart for tools if it is in the center of the shop.
110v is not much of a concern but if you need 220v is it available in the center without additional wiring?
Some folks who do hollowing set it with the headstock against the wall with the lathe 90; others angle the lathe 45. Depends on what you want to turn, whether your headstock pivots or slides, and other considerations.
View TheDane's profile
TheDane
5399 posts in 3628 days
#11 posted 12-06-2014 04:44 PM
Mine is on a rolling cabinet …
Click for details
This arrangement gives me the most flexibility … my shop is only 14’ x 23’, so I need to reposition tools depending on the project at hand. At some point in the next year or two, I plan to graduate to one of the ‘big boy lathes’ (e.g. Robust, Powermatic, etc.) which means I will need to do some reconfiguration.
View GT350's profile
GT350
362 posts in 1947 days
#12 posted 12-06-2014 04:44 PM
I don’t use my lathe a lot but mine is against a wall and I haven’t had any problems, I just sweep under it. As far as bolting it down, if it is vibrating a lot, you might consider adding weight like sandbags to the bottom. Mine is a Jet with heavy cast iron legs and it doesn’t move at all.
Mike
View John's profile
John
1142 posts in 1235 days
#13 posted 12-06-2014 06:12 PM
Hi Rick. My small lathe is on wheels. My large one is bolted to the floor by the wall, not ideal but unless I get a huge shop that is where it will be. The only thing I notice is when using my longest gouge and working out from the centre of a bowl the butt of the gouge is almost touching the wall.
John
-- John, Sunshine Coast, BC, Canada.
View Woodknack's profile
Woodknack
11478 posts in 2346 days
#14 posted 12-06-2014 06:24 PM
I’ve done both, preference is against a wall. If I had a really large lathe and only did turning, I might move it away from the wall.
Rick Bailey
#15 posted 12-06-2014 06:49 PM
Hey Rick. You never said how dig your tool is. :) If it s a bigun I can t help ya. I have a midi lathe on a rolling stand I built with 2×4 s. I m stuck in a single car garage, but it works great.
- Mark
I guess that would help, here you go.
