Hand saw TPI for joinery
« back to Hand Tools forum
Forum topic by giser3546 posted 12-04-2014 04:31 PM 1464 views 0 times favorited 19 replies Add to Favorites Watch
View giser3546's profile
giser3546
179 posts in 1341 days
12-04-2014 04:31 PM
I have one 14 TPI Veritas hand saw and I’ve used it just about every time I cut dovetails or M&T. I have noticed I have a hard time getting the saw to stay on a mark especially when just starting out. At first a attributed that to my inexperience but Lately I’ve been wondering if a higher TPI would make that easier. Is there a significant difference between a 14 or 16 tpi and maybe a 20 tpi fine cut dovetail saw?... or should I just keep practicing with what I have?
-- "If you wait for it to rain, It will"
19 replies so far
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2239 days
#1 posted 12-04-2014 06:31 PM
What’s your technique for starting the saw? I have the Veritas 14 tpi dovetail saw and haven’t noticed a problem with it. I use my thumb as a guide, and do a pull-stoke or two at an angle on the corner, then once it’s started extend the kerf across the piece. I did notice that when I first bought the saw, it was more difficult to start than after I’d put some hours on it. I think the teeth were really sharp and grabbing more. I also use a crosscut-filed saw when cutting tenon shoulders.
giser3546
#2 posted 12-04-2014 07:25 PM
I usually use my chisel to cut out a groove on the waste side of the line and use that along with my thumb to guide the blade. I use the same saw and procedure on the shoulders.
View waho6o9's profile
waho6o9
8064 posts in 2446 days
#3 posted 12-04-2014 07:26 PM
“I have one 14 TPI Veritas hand saw and I’ve used it just about every time I cut dovetails or M&T. I have noticed I have a hard time getting the saw to stay on a mark especially when just starting out.”
What kind of a mark?
If it’s a pencil line the saw may wander.
Some folks use a marking knife and then chisel along the line to keep the saw in line.
Paul Sellers has a video on saw set:
https://www.youtube.com/watch?v=CvbakS8ZjKY
View JohnChung's profile
JohnChung
396 posts in 1943 days
#4 posted 12-05-2014 03:55 AM
There are a few ways to start the saw. I generally pull at the edge of the wood. The angle is not steep as I do not want to have breakouts.
View ElChe's profile
ElChe
630 posts in 1205 days
#5 posted 12-05-2014 04:21 AM
I find that if I GENTLY hold the saw and almost float the saw as i let the saw start the cut I find it is much easier to cut to a line. I’m still in the practice stage in terms of dovetails. I’m taking a dovetail class next year and in the meantime I practice my pin cuts and my tail cuts. Im getting better cutting to the correct side of the mark. My saw is a 15 tpi.
View rjpat's profile
rjpat
41 posts in 1847 days
#6 posted 12-05-2014 03:39 PM
The Renaissance Woodworker has a video on how to sharpen that saw to make it easier to start.
View DrDirt's profile
DrDirt
4418 posts in 3611 days
#7 posted 12-05-2014 03:57 PM
I would keep practicing.
I have used the Japanese saws, and I like it, but it does take a lot of strokes to make the cut with such fine teeth.
It could be that the set on a few of the teeth are off on your saw, such that it is pulling to one side.
Does it always pull one way, or is it random?
View mds2's profile
mds2
310 posts in 1813 days
#8 posted 12-05-2014 04:00 PM
I have the same saw and thought the same thing when I started using it. It was a “grabby” and hard to get started. But I think it was just my technique. Let the saw do the cutting and dont force it.
View bobro's profile
bobro
319 posts in 1180 days
#9 posted 12-05-2014 05:15 PM
I use my left thumb as a kind of fence or register, like Ed and giser. And point my right finger, not have it in the handle. Sometimes I put out my right middle finger, forward and down as a sort of guide on the right side of the blade as well, at the very beginning of the cut- that way you are forced to go gently.
On crumbly woods, or very hard slick woods that make the saw want to skid around, it makes all the difference to chisel a little start as the guys are describing, even if it’s just at the corner and not all the way across.
-- Lao Ma: You are so full of anger and hatred. Xena: Everybody's gotta be full of something.
View summerfi's profile
summerfi
3764 posts in 1556 days
#10 posted 12-05-2014 05:27 PM
When you say, “I have a hard time getting the saw to stay on a mark,” do you mean it jumps around when you’re starting the cut, or it gradually wanders off the line once you get into the cut?
-- Bob, Missoula, MT -- Rocky Mountain Saw Works http://www.rmsaws.com/p/about-us.html
View mramseyISU's profile
mramseyISU
529 posts in 1414 days
#11 posted 12-05-2014 09:59 PM
- mds2
I have the same saw and that’s the best advise there is for this. I find that when I push to hard the saw goes all over the place. Easy does it and it’ll sing.
-- Trust me I'm an engineer.
View Derek Cohen's profile
Derek Cohen
358 posts in 3837 days
#12 posted 12-08-2014 11:48 AM
Lift the saw up like this and you will find it much easier to start ..
If you start the cut on the near edge so that one can follow the two adjoining marked lines, and then level the saw. This also effectively reduced the rake of the teeth and makes for an easy start.
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
TheWoodenOyster
1311 posts in 1804 days
#13 posted 12-08-2014 02:40 PM
I have that 14 TPI Veritas and I’m not a fan. I got a high tooth, maybe 20 or 25 TPI Japanese Dozuki and I much prefer it. Much thinner kerf and easier to start. They aren’t too expensive, you should give them a shot.
-- The Wood Is Your Oyster
giser3546
#14 posted 12-08-2014 09:35 PM
Thanks for the feedback guys. I have noticed that it gets easier when I loosen my grip.. but starting out is still difficult to get spot on. I will give it some thought.
BinghamtonEd
#15 posted 12-08-2014 09:37 PM
One thing I learned early with this saw is, in addition to the very light grip, if it doesn’t start easily, pick it up and do a pull stroke again. Trying to force it to start cause it to jump off the line, seemingly always into the non-waste area.
